Old 02-27-2003, 09:31 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
overlander- thanks for the tips. i was using my low watt soldering iron for electronics, which was taking a long time. i finaly got it done but it's not as nice as i wanted, i'm tempted to redo it using my higher watt iron. i do all the things you described. (i read the back of the soldering iron package and other soldering tools to learn how) it took some filing to clean up the ugly soldering and i polished it a little. nice and shiny! i posted pictures this morning. let me know if you think it's ok.
about the gear box, unfortunately i don't have much more money to put into this. any idea where to get a higher gear ratio worm gear? i'll get one of those gear boxes for my next one!
i plan on getting a small vise (o got the ok for this a while ago, but do to snow and other priorities, it's beend delayed) this weekend, so i'll try to get the spur gear off then, thanks for the how-to.
Old 02-28-2003, 12:12 AM
arch2b's Avatar
off topic, sorry
nothing new for my project tonight. i spent a couple of hours working on my ultimate light set for my overland. i installed the 4 white leds for the light bar in a peice of 3/32x3/16 brass tube i had handy!
tested the headlights and lightbar.
Old 02-28-2003, 05:08 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
:ö: Arch!,
man that light set you made are cool!!!
great job man!
hehehe
Old 02-28-2003, 05:10 AM
killer's Avatar
pic of the u-joint
:ö:
hehehe
Old 02-28-2003, 05:11 AM
killer's Avatar
:ö: the chassis
hehehe
killer's Avatar
:ö: length
hehehe
Old 02-28-2003, 05:13 AM
killer's Avatar
:ö: steering knuckles with ballbearing.
hehehe
Old 02-28-2003, 05:21 AM
killer's Avatar
:ö: to post clearer pics soon.
hehehe
Old 02-28-2003, 12:46 PM
Overlander's Avatar
Overlander Overlander is offline
Overworked
arch,
I checked out your frame. It looks great. Bending and soldering rectangle tube is a beeotch. Your Overland lights look good too! A very clean install and wireing job. Being a perfectionist is good. An old retired modeler guy once told me that someone is always looking at your work. Before he told me that, my stuff was sloppy.
Killer,
Your u-joints are incredible! Hand-made! Wow!
How did you attach the knuckle control points to the bearings?
_______________
I just like to build.
Micro RC for way over a decade
Old 02-28-2003, 10:05 PM
arch2b's Avatar
killer- remarkable work
Old 03-01-2003, 03:53 AM
killer's Avatar
Originally posted by Overlander
Killer,
:ö:
Overlander,
shucks! thanks man , and one more thing, this u-joint is made of 2mm steel shaft which is way much stronger than brass, twisting this out-of -shape is close to impossible for such a small rc truck , how did i attach the control points on the bearing?.. i used this brass tube that came along with my 1/10 Tamiya TB-01 long suspension set (it's a spare parts for my 1/10 rally car), this tubes have a hole that is exactly the same size as the ballbearing i used, then i solder the control points on the brass tubes then secure the bearing inside the tube with a quick drying CA.
hehehe
Old 03-01-2003, 04:01 AM
killer's Avatar
:ö: thanks Arch!
hehehe
Old 03-01-2003, 10:44 AM
killer's Avatar
:ö: this is the design of my steering knuckles ...
hehehe
Old 03-01-2003, 11:09 AM
killer's Avatar
:ö: here is the simpliest way of making a steering knuckles for all-wheel-drive truck, but with this design, you cannot adjust camber.
hehehe
Old 03-01-2003, 11:12 AM
Squishy's Avatar
Squishy Squishy is offline
Quack
Killer, great job on the frame and u-joint! I wish i could do that good of a job.
Losi 1/36 Micro-Desert Truck arch2b Micro-T General 2 11-11-2007 07:18 PM
1/87 scale Truck Rob1962 TTTT 1 11-17-2006 11:56 AM
Im intrested in makeing a 1/87 4WD buggy/stadium truck grimmreap3r TTTT 6 02-09-2006 06:16 AM
selling a 1/87 truck complete fastboy TTTT 45 10-17-2003 10:36 AM
1/87 truck (tttt) Squishy For Sale/Trade 3 02-10-2003 10:18 PM
