Old 02-22-2003, 07:46 PM
Overlander's Avatar
Overlander Overlander is offline
Overworked
This shows the assembly from the bottom. The servo clears perfectly:
_______________
I just like to build.
Micro RC for way over a decade
Old 02-22-2003, 07:53 PM
Overlander's Avatar
Overworked
This one shows a lot. Notice the two 1.5mm holes in the front end of the frame (top of picture) for mounting the drivers cab later. Also notice how the frame fits nice and flat on the bottom of the cargo bed. As I said before, this is my second truck and I want to use little or no glue. Everything will be fastened with screws.
_______________
Old 02-23-2003, 02:56 PM
Overlander's Avatar
Overworked
This one shows the simple steering linkage. Also notice the springs on either side of the gearbox. These allow the gearbox to tilt from side to side.
_______________
Old 02-23-2003, 02:59 PM
Overlander's Avatar
Overworked
Now that I have the gearbox placement, the body height, and the steering placement and linkage worked out and assembled, I can start laying out and designing the electronics and lights.
_______________
Old 02-23-2003, 03:49 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
i isp has been out since friday night and it has just now come back up this (sunday) afternoon. and look at the amazing pictures overlander has posted. i am soo jealous
overlander- i ended up painting my man white i didn't know yours was as well. it looks like yours came white?
Old 02-23-2003, 04:07 PM
Overlander's Avatar
Overworked
Hi arch,
Yes, the one I am building now is the MAN 5t Prolog Offroad truck. It is white plastic.
Here is the model:
http://www.discounttrainsonline.com/...m625-1647.html
Did you get your parts yet?
_______________
Old 02-23-2003, 07:48 PM
arch2b's Avatar
overlander-
sorry my responses might be infrequent. my isp went out for a couple of hours, again. a repair guy is comming out monday. atleast it's been in and out today, so i've gotten some emails.
Old 02-23-2003, 09:03 PM
arch2b's Avatar
as i mentioned earlier, i painted my 5t man white. i think it turned out well. since the paint can't get into the tiny outlines perfectly, it gives shadow lines, texture and, in places, makes the details easier to see. i reassembled it for the picture. sorry it's soo big. as soon as mini z/tiny can get my album on mzr fixed, i'll be posting all my tttt pictures to a tttt album in my album. i'll come back ad edit this then.
Old 02-23-2003, 09:50 PM
Overlander's Avatar
Overworked
Hey! That white paint looks great!
I cant paint to save my life! Did you use an air brush? When I try to spray paint from a can, I always seem to get it on too thick. That job you did puts my painting skills to shame
_______________
Old 02-24-2003, 09:16 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
Cool
:ö: arch,
don't tell me that, that was a green truck before?!!!.. great job man!
hehehe
Old 02-24-2003, 09:26 AM
arch2b's Avatar
thanks for the comliments, it's nice when they come from such talented persons as yourselves when i see your work (killer, overlander and all the germans) i feel like i'm out of my league .
since i'm at work, i have to be brief. i do get to check in though ! (the life of an architect is busy and unglamourous) i got my tttt album in my mzr album! i'll begin to post pictures tonight, begining with my paint job. i'm actually thinking about a pale porche yellow or red for my other 5t man. i really like the red one in the pictures thorsten posted. when i'm finished building the thing, i'll go back and try to add that level of detail to the painting.
overlander- where do you find your solid brass stock? i've only seen the k&s stuff which is mostly hollow shapes. i plan on leaning how to use my new dremel as soon as i get a hobby vise. i don't want to loose any fingers.
one more, is there a glue that i can use to glue some of the plastic detail peices to the brass frame work?
Old 02-24-2003, 04:27 PM
Overlander's Avatar
Overworked
The brass bar I used for my chassis is from a 1/8" plate I had lying around. You can buy plate and bar stock from a metals store. Look up metals in your local telephone book. Most places have bins of scrap and misc. chunks of brass and aluminum. Just call and ask.
How did you paint that little bugger?
_______________
Old 02-24-2003, 04:36 PM
Overlander's Avatar
Overworked
Arch,
Here is an excellent link for small quantities of metal:
http://www.onlinemetals.com/
It may be simpler to go to a local scrap metal place though. Check them both out. Remember, you dont need to use big plates for a brass frame. Square rails are fine. The only reason I used a big ass plate was to experiment. I also think it will help keep the center of gravity lower. My UNIMOG flips over pretty easily because the batteries are up high.
As far as glue, use thick CA glue. Make sure you clean the brass with acetone first. It also helps to abrade (roughen) the surface of the plastic and brass slightly. Use an emery board for fingernails for this.
_______________
Old 02-24-2003, 09:52 PM
arch2b's Avatar
overlander- thanks for the info. i'll try hitting up the local metal shops for scrap brass this weekend.
incredible tool collection by the way. i have to work on a folding card table and everything has to fit into a box when i'm done.
i posted some pictures in my album (ttt section). explained how i painted the 5t man.
as stated before, i found a guy that sold me the following for $123.00. he has stuff on ebay reglularly. you can email him for a custom package and his prices are good. what i got was atleast $20 cheaper than the next quote from an online store. he is generally good about replying to emails; Tlrascal@aol.com . this is probably your best source until TINYRC starts stocking GWS parts .
2 - BP101 Plain Bearing - JR/Hitec (PICO STD)
1 - GWS R4P Receiver With XTAL
1 - GWT-4A Transmitter (F-Negative Shift) with XTAL
1 - GWS MC-2002 Peak Detect field charger
Old 02-24-2003, 11:03 PM
Overlander's Avatar
Overworked
Hey Arch,
I checked out your album. It looks like your well on your way. Dont you hate tearing up a perfectly good Faller bus?
That pico servo, are you going to make the ESC from that?
Also, I was going to suggest using a diferent switch. That faller one is huge!
_______________
Losi 1/36 Micro-Desert Truck arch2b Micro-T General 2 11-11-2007 06:18 PM
1/87 scale Truck Rob1962 TTTT 1 11-17-2006 10:56 AM
Im intrested in makeing a 1/87 4WD buggy/stadium truck grimmreap3r TTTT 6 02-09-2006 05:16 AM
selling a 1/87 truck complete fastboy TTTT 45 10-17-2003 09:36 AM
1/87 truck (tttt) Squishy For Sale/Trade 3 02-10-2003 09:18 PM
