Old 11-06-2003, 07:31 PM
Lord_HelmetR34's Avatar
Lord_HelmetR34 Lord_HelmetR34 is offline
Bit Crazy
When I start to slide, I apply a little reverse lock by tapping/releasing the steering button very quickly. This helps keep me from overcorrecting and spinning out. Dust on floors is awesome for drifting no matter what tires you may be running
Dubshop Customs
Old 11-07-2003, 06:07 AM
geofroley's Avatar
geofroley geofroley is offline
R34 Skyline is God
Send a message via AIM to geofroley
wouldn't the dust come off eventually? I still think theres some other thing I can put on the tires to drift.
Old 11-07-2003, 07:56 AM
ownzorzor ownzorzor is offline
not really... you actually accumulate more and more if you don't clean up. That's what happens to my car.
Old 11-11-2003, 02:04 PM
geofroley's Avatar
R34 Skyline is God
New drift method!
I jsut thought of this a couple of days ago: Put tape on your tires! Alot of tape is so smooth you may be able to get your car to drift really well! Scotch tape is what I am going to use.
Old 11-13-2003, 04:46 PM
maxximum attack
Do not tape the whole tire!
put a very thin strip on ALL four tires. Get some electrical tape and devide it length-ways 4 times. In half, then that half, in half etc. It also helps to have a little more weight at the back. This shifts the C.O.G further to the back. If you wanto see the results, check alittle earlier in these posts and you will see my drift vid.
The use of verylittle tape is so that the tires can break traction but not lose all of it.
Hope that helps.
Old 11-14-2003, 06:09 AM
geofroley's Avatar
R34 Skyline is God
Will scotch tape work though? By the way thanks.
My Bit: Phast motor (Orange)
Soon to come: (Undecided) Custom Rims
Old 11-14-2003, 04:32 PM
maxximum attack
I have never used scotch tape. But I guess it would work.
Glad to help
Old 11-14-2003, 04:45 PM
geofroley's Avatar
R34 Skyline is God
Can I cut the tape instead of fold it?
Old 11-23-2003, 11:21 PM
maxximum attack
Of course you cut it. It wont stick if you fold it.
Old 12-25-2003, 07:14 PM
titaniumonkey titaniumonkey is offline
I haven't been able to drift yet but I can power slide through my turns and that looks about the same as drifting through a turn so I'll post my settings for my car
AE86 shell
2speed chassis
2.2 micro b motors
clone slicks on back wheels
hard tires in front
some dust
Old 12-29-2003, 08:31 PM
SHIFT_DRIFT's Avatar
5Zigen
mine is:
Mitsu LanEvo IV (silver)
"BOOSTER" chassi
front slick med
rear panther plasticy rubber hards
3.4 with orange gears
soft stabilizer bar
Try And Sleep Now.
DRIFT my ANTI-rice
Old 01-17-2004, 02:53 AM
otobot's Avatar
otobot otobot is offline
otobots transform!
DRIFTIN'
hey! newbie here n totally into driftin...
i hav a booster set from d auto modelista set...
my specs are...
stabs - stock
gears - 9:86:1
engine - 3.0
rear - hard
front - soft
i change my body from time to tim, but im usin d evo7 rally ryt now...
driftin - ol u do is hit d boosts, den wen its fast enuf, let go of d acceleratin n turn...woosh! n der u go, u just drifted...
Old 02-03-2004, 01:33 AM
Ooo I noticed you have been posting a lot on this topic...
You want stretched out tires? Use front tires on the back axles!!
Old 02-11-2004, 06:04 AM
otobot's Avatar
otobots transform!
Talking
i went for the easy way...i bought d drift set...har har har!!
Old 02-13-2004, 03:28 AM
bitcharej bitcharej is offline
Send a message via AIM to bitcharej
RE: Bit Char-Drift
My car was set up:
-Car: red AE86
-Freaquency: 35MHz Booster
-rear: drifting wheel/axle
-front:custom from drifting wheels (moded fromt drifting wheel/axle)
-motor: 4.2
-stablizer: medium
I got a video that I made http://www.imagestation.com/picture/...6/f9b75658.mpg I use salt as gravel to make the car slide
"Stop being such a pu$$y!" Arnold S.
-Zenki Corolla GTS (coupe)
<img src="http://www.imagestation.com/picture/sraid71/p1a49c9002793c24d3305d7070f0044dd/fb9b4212.gif">
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 07:35 AM
DRIFTERS ... anyone ever seen a Hirobo DRICON kylelucas Other Tiny RCs 5 10-06-2004 08:29 AM
attention XMODS drifters Daazndood XMODS 29 11-27-2003 06:27 PM
Boosters are good drifters! Zephyranthes Bit Char-G / MicroSizers 2 04-02-2003 12:56 AM
