Old 01-07-2003, 06:03 AM
neo_m neo_m is offline
Break it in????
How do you do this with a char-g. I know with the big gas cars you have to put about for a couple of tanks.
Do you just drive it as normal or do you have to prop up the back wheels and let them spin for a while.
You know why?.... Because he can!
Old 01-07-2003, 06:24 AM
Shypo's Avatar
Shypo Shypo is offline
Regulator
just drive it normally and after about 4-5 charges and runs it should be broken in
go fast, be free, with low CC
Old 01-07-2003, 07:01 AM
ok thanx
Old 01-07-2003, 07:50 AM
johnrtse's Avatar
johnrtse johnrtse is offline
A must-do!!!!
I have found that my cars run much better if I break in a new motor. I do this by putting the motor in the car, charging the battery, putting the car upside down on its roof, and running the motor with no load - for (2) battery charges.
On the first charge, I will alternate going backwards and forwards, for about 45-60 seconds in each direction. On the second charge I only go in forward, until the battery is drained.
This breaks in the motor commutator brushes and makes for a better performing car!
John
"It takes a Mopar to catch a Mopar!" - Vanishing Point
Old 01-07-2003, 09:09 AM
cool thanx.
ill do that with the new engines
Old 01-07-2003, 01:36 PM
evileric evileric is offline
MSN:eric_exec@hotmail.com
Thanks for the tip
Im gonna take a break from the tiny rc scene striderpunk Miscellaneous Discussion 1 11-24-2003 04:46 PM
x-mods wires break easy aggroskater03 XMODS 2 11-18-2003 07:52 PM
Any Tips to not break wires Smurf Bit Char-G / MicroSizers 5 05-15-2003 02:09 PM
Is there such thing as a break in period for a motor? neoGTR22 Bit Char-G / MicroSizers 1 03-10-2003 04:40 PM
Break in That new Motor nivirt Bit Char-G Parts and Hop-Ups 15 09-22-2002 09:43 AM
