Old 02-06-2003, 01:30 AM
Lel Lel is offline
Is 3.8 motor the best?
I've noticed that this site's online store, as well as other retailers sell motors ranging from 1.0 all the way up to 3.8 and the new r-spec and formula 34. My question is, why would you want to get a 1.6, 2.6, or 3.0? Do they offer more torque than their larger counterparts, because if they don't, then wouldn't the largest motor be the best option?
Old 02-06-2003, 08:05 AM
grilleguard2k grilleguard2k is offline
Send a message via AIM to grilleguard2k
You must mean fastest...all motors are the same size.
Would YOU hit it?
Old 02-06-2003, 08:12 AM
savage sound's Avatar
savage sound savage sound is offline
Fast motors rock if your just messing around in open areas, but if your trying to race on a track its pretty difficult to hit a hard turn with a 3.8! even if you manage to make the turn odds are youll flip before long. i usally start with a 1.0 or 2.2 on a new track and then work my way up if im getting the hang of it. another thing is torque, if your on light carpet its a pretty good strain on the 3.8. a lot of times youll get stuck or not even move. hope this helps!
jack of all trades master of nothing!
Old 02-06-2003, 08:48 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
i have a gas powered motor in my car. its pretty nice.
Old 02-06-2003, 12:56 PM
Subie Driver Subie Driver is offline
'00 Subaru Impreza 2.5 RS
Is it a rotary?
27MHz Microsizer White Peugeot 206: 3.8, NiMH
49MHz Microsizer Yellow Lancer Exolution: stock
27MHz LXX Char-G Xanavi Skyline GT-R: 3.0
27MHz ZipZap Yellow F&F Civic: 2.6, Carbon Fiber-look hood, lowered, sport tires, turbo gears
Old 02-06-2003, 01:05 PM
hogjowlz's Avatar
i was lying
Old 02-06-2003, 04:34 PM
i was lying
Hence the smilie.
ANyways, might as well answer the original question. There is no"best" motor. Different motors are better suited to different kinds of racing. For a really tight, twisty, technical course, then a 1.6 or a 2.2 might be the best balace between speed and control. But for drag racing, then the 3.8 might be the best bet. And the gears make a difference, too. A 3.8 with the stock gears is tough to control in turns due to wheelspins and quicker acceleration. But a 3.8 with the 8.25:1 is much easier to drive and turn. It all depends on what you are using the car for, and your driving style, combined with your gear/motor combo. Try some different setups and see what's best for you.
Old 02-07-2003, 01:34 AM
Lel Lel is offline
Thanks for all the info guys, I thought the larger the motor, the more torque and top-end speed they had, but I guess not. However, couldn't you technically compensate for the lack of torque in say, a 3.0 motor with a 12:1 gear ratio, which would (I'm guessing) make it equal to a 2.2, with the added bonus of having high top-end?
Old 02-07-2003, 11:02 AM
ffctp's Avatar
ffctp ffctp is offline
.pylonspeed.
I have a 3.8 motor and boost car coming, and I'll be interested to see how it works with different gears. It seems like a lot of people are asking "which motor is fastest," but that seems like a kind of pointless question unless you only intend to go in a vaguely straight line.
All these two speed cars hitting the market might change that a bit though, since you should be able to tool around at a realistic speed and use little bursts here and there.
But I've been wondering about the torque and such too ... I could see having issues racing a car that gets to speed faster than yours if there's a lot of turns involved.
Current car: Bensu Peugot 206. Tomy 3.0. Metallic flake blue paint and cutesy stickers.
Somewhere in the air between Hong Kong and LA: LXX Boost, 3.8 motor, other goodies.
Will perfection 3.8 and 150 mAH NiMH cell work with my zip zap? Please respond ASAP. ibbored ZipZaps 5 09-11-2003 11:25 AM
My 3.8 has come!!!!! Zephyranthes Bit Char-G / MicroSizers 1 02-16-2003 08:57 AM
I want to give a free 3.8 motor to someone for X-mas bitchar-gmotors Bit Char-G / MicroSizers 10 12-25-2002 03:23 PM
3.2 or 3.8 ZIZI ZipZaps 6 11-26-2002 06:47 PM
2.2 vs. 2.6 vs. 3.8 Namuna Bit Char-G / MicroSizers 14 08-23-2002 09:30 AM
