12-03-2002, 05:15 PM
Evo VII
Go
where did u buy it?
what different frequencies are available?
are there differentsets or versions of it with different scoops?
thanks a lot
________
Buy no2
12-03-2002, 07:24 PM
i bought at a japan expo in LA it was the last one they had. There are two frequencies 35mhz and 45 mhz. there are only two out so far one with a arm like the mine and and another one with a scoop that goes up here a pic from the tomy site.
12-03-2002, 10:52 PM
thanks a lot
There are two different trucks. Raise Tiger with a scoop to lift things out of the way(the orange one). And Rumble Claw(the blue one), that has a set of "fangs" for dragging things around.
Truckian
12-11-2002, 02:11 PM
I have the Raise Tiger (the red Wild Char-g), and it rocks! You can use it to lift up and roll over cars and help it get over obstacles.
The wheels are not interchangeable with other Bits because there are no axles connecting any of them. They are all independently "snapped" onto a hub.
What is cool is - there are two motors in them. One motor to move the wheels and another for the fork lift. I'm trying to figure a way to change the fork motor. It's currently sodered to the wires. If i could get a 3.0 motor in there, this thing would be a monster
Oh, and the steering is controlled sorta like the DigiQ's. It is rear wheel driven, but when you want to turn it send more power to the left or right wheel to make it turn.
______________________________
Automodelista: 3.8, 150mah, spring sus.
Wild-G: Raise Tiger w/3.8@the wheels & 2.2@the plow, 150mah
Lancer EVO: 3.0, 150mah, drift set
Hummer shell: 3.8, 150mah, spring sus.
12-11-2002, 09:15 PM
yo heres a link to a website i made with a few more pics of my wild char-g and a few other of my bits
12-15-2002, 03:06 PM
Micro R/C'er in Da Burgh
Where did the Hummer body come from? BAE
Smaller models, more control
12-17-2002, 10:24 AM
i found a cart at the mall (in Palisades in NY) that sells Bit Clones. They were selling clone bodies for around $10. I also got Hummer type tires from them. They're ribbed, and bigger than normal Bit tires so the chassis has to be trimmed a tiny bit so the rear tires can spin freely. They're a equivelant to 'medium' Bit tires.
I think the Hummer body is a Bullet clone. I recommend checking out the local mall for them
they also had it in black and yellow. i wanted the desert camo one -
http://www.ToyEast.com/catlist2.asp?catid=304
