10-16-2002, 12:57 PM
Microrcfool
Charging station
i'm going to build a stand alone charging station that has both a zip zap charging pad and a microsizer/bitchar-g pad. with a flip of a switch i'll be able to either run 1.5/3/4.5 volts of charging current to either pad or both at once. I decided to use c size batterys for longevity and feild use instead of a plug in type although I may add that option later down the road.  I'll do a write up on it when i'm finished.
"What's a low fool?" lol
10-16-2002, 01:02 PM
Sounds good!
Good luck with it!
10-19-2002, 05:11 PM
Microrcfool
well, I finished it today. I've got 4 charger pads(2 zz's and 2 microsizers) and two swithes on the side that allow me to either charge at 3 volts or 6 volts. I'll try to get some pics today of everything I've got.
10-19-2002, 05:33 PM
It's super useless!
Wow, four charging stations in one. Good job there. Now we wait for the pictures!!!
10-20-2002, 01:15 PM
You guys seem to knowledgable...
I have a Bit modded with two 150mAH NiMH cells. Since the controller can't charge the two cells, I charge it using a stand alone charger hooked up to 3 AA's.
I figure that's 4.5V right?
I built a plug-in charger that runs on 3V. Here's a link: http://tinyrc.com/forums/showthread....+Alone+Charger
My question is could I get a 4.5V or higher power supply, hook that up to the plug-in charger and use the that to charge my twin cell Bit?
Is it safe? I won't blow anything up?
10-21-2002, 09:16 AM
Microrcfool
it should be safe. You might even be able to find a switchable current, plug-in adaptor. they make them for cars that plug into the lighter. I'll do some searching and see what I can find.
10-21-2002, 06:28 PM
Thanks lowerdfool,
I went to Radio Shack to check out what they had power supply-wise.
I found a switchable power supply rated from 1V - 9V (I think).
The box also said 2.5A. I didn't buy it, since the power supply I already have is 700mAH and I don't know what those numbers mean.
Could someone explain mAH and A?
I know that 150mAH puts out more power than a 120mAH etc...,
but how does 2.5A compare?
Help!
10-21-2002, 08:36 PM
I'm no expert, but I believe "mAH" stands for "milliamp hours", which is a measure of how long the battery will last under a given load. A 150mAH doesn't put out more power than a 120mAH battery, but it can hold a larger charge capacity, for longer battery life.
"A", or "amps/amperage" is a measure of electrical current. The amperage rating of 2.5A means that that particular power supply is rated to be used with equipment that will draw no more than 2.5 amps. Drawing higher than 2.5 amps will probably damage it.
{edit}
I guess I should have added:
You say that your current power supply is rated at 700mAH, (probably 700mA). I am very positive that charging a mini r/c car is not drawing anywhere near 2.5 amps, especially if your 700mA is working, so the one you were considering at Radio Shack is more than enough to handle the job....
10-22-2002, 11:32 AM
loweredfool .. sounds great .. are you going to give us step-by-step instructions??
Please.........
10-23-2002, 12:40 AM
OLDS442,
Thanks, I think I get the meaning of mAH, battery-wise.
BUT , I'm still having a hard time understanding amps.
I'll reword my question:
What is the difference between charging with 3V @ 2.5A and 3V @ 700mA?
Does 2.5A make it charge faster?
10-23-2002, 02:10 PM
There is no difference really. It won't make charging necessarily faster. The amperage rating is to let you know how much current draw the power supply can handle under load, without failing. So, you wouldn't want to use a power supply rated at 2.5A to run a piece of equipment that draws more than 2.5A. If you do, the power supply will likely fail, (i.e. smoke, burn, blow up, etc.  ) Basically, you want to make sure that the amperage rating of your power supply will be greater than the actual load that you draw from it.
As I said before, I believe your 700mA rated power supply will work fine, (assuming it is at least 3V). I don't know the exact draw of the batteries when charging, but I doubt it's very high. My stand-alone charger uses a Radio Shack 1.5-12V 300mA AC to DC Adapter, (cat #273-1662), that was salvaged from my junkbox. I soldered it into a Motor Works charging base. It charges all of my cars, including my dual 110mAH NiMH battery MicroSizer + 3.8 motor. I've used it multiple times every day for over a month now and it's still going strong....
10-23-2002, 11:22 PM
Some info about charging with different adapters was posted in another thread.
10-24-2002, 09:38 PM
Thanks for the link gRC!
 Still kinda intimidating, but I think I'm starting to understand!
10-29-2002, 12:10 PM
Microrcfool
Here's the wire schematics for a charging station like what I've made. I haven't yet tested the voltage when 4 cars are on but I can successfully charge 2 at the same time without any drop in voltage as long as the batteries are new. I will probably in the near future get an ac/dc adaptor to plug into a wall that way I don't have to continue to change batteries as long as I'm at home or somewhere with an outlet.
and for the pic....
10-30-2002, 10:02 AM
Off to Bit Science...
