Old 01-08-2004, 09:59 PM
lemans23's Avatar
lemans23 lemans23 is offline
GT3 Drift Master
Unhappy Please Reply! Serious Issues! Car Doesn't Work At All!
EVERYONE! i am in a dire situation. i went to install my drift motor and in the process, i broke the antenna wire. i re-soldered it and screwed it back in. a little thereafter, i undid the solder on the 5th cell on the POS side. i re did it and turned on the car. it had the usual feedback, like the wheels straighten out. i turned on the reciever, no feedback. i hit the gas, nothing. i tried to steer it, nothing. i looked over the car, and i can't see anything. i think it is a controller problem because when i curn on the car, i get a good amount of feedback. the light is bright red, and i replaced the battery. i have no idea what is going on, so can someone please help me to fix this quandry?
RSX XMOD:
Stage 2 yellow motor
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 01-08-2004, 10:07 PM
ax0n
make sure your crystals are both inserted correctly and firmly seated.
Old 01-08-2004, 10:21 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
make sure you got a good connection when you resoldered the antenna wire and that the surface between teh metal tab and the actual antenna is clean for a good connection
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-08-2004, 10:23 PM
lemans23's Avatar
GT3 Drift Master
i know that u don't doubt me, but i said that i checked everything. all crystals are in place, and in firmly.
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 01-08-2004, 10:34 PM
itsme
fried receiver?
Old 01-09-2004, 07:31 AM
ax0n
Hmm... mine JUST started doing this same thing... only twitches with the on/off switch, no response to the controller. It happened after I slid into my cat's water bowl.
I broke it allll the way down, pulled out the ESC/Reciever board, and cleaned them with anhydrous then an air compressor. While I was at it, I swabbed all the other crap out of the chassis. I run my xmods outdoors a LOT, so there was a bit of sand, dirt, and other debris in there. Cleaned out the heatsink, cleaned all the heatsink grease off the heatsink and thr chips, put 2 little dabs of arctic silver 3 on the chips and put everything back together. She works now.
Might be pure coincidence, but maybe let it sit for a few days and see if it works? Or if you dare, take it apart and clean/dry it out. It could also be something other than water, like just good old fashioned fried circuitry.
Old 01-09-2004, 07:38 AM
lemans23's Avatar
GT3 Drift Master
Re: ...
Originally posted by itsme
fried receiver?
can you do that?
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 01-09-2004, 09:10 AM
aperson's Avatar
aperson aperson is offline
check the little wires going to the little pcb board where the antenna wire and crystal plug in. that was the problem with the electronics i ordered. i just had to strip it and resolder it. that seems to be a common problem with these.
Old 01-09-2004, 09:40 PM
KnotHole's Avatar
KnotHole KnotHole is offline
JesUSAves
Unhappy
I agree with ax0n. I wish you good luck getting it working again. I'm not sure what else it could be.
Old 01-09-2004, 11:06 PM
lemans23's Avatar
GT3 Drift Master
GRRR
i went to rat shack a couple hrs ago, and i talked to the shakies. the dude went into a huge thing about how cool the 5th cell mod was. great, i didn't care. so he told me to buy new batteries cause they were dead. so i did that and i went home and installed 4 new batts and i undid that black wire with the 5th cell wired in and attatched a new 22-gauge wire. it's green so it looks pretty customized . but anyway, i went back and the dude thinks i fried something with the 5 cells. so i am going back 2maro to talk to the manager. but can someone help me to unassemble my car to inspect it? i wanna look at the esc and stuff that axon said. i really have no idea on how to do that.
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 01-10-2004, 09:22 PM
lemans23's Avatar
GT3 Drift Master
can anyone help me unassemble the car?
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 01-12-2004, 09:30 AM
aperson's Avatar
nice avatar. all you have to do is remove everything from the front end. 4 that hold the towers on, 2 that hold the bottom of the knuckles on. remove those and the 2 rear screws on the plate on top. then remove the battery adjustment screws on top. then remove the 2 bottom screws that hold the black plate onto the rest of the chassis. take out the rear end as an assembly and take out the driveshaft too. then remove the the screws that are on both sides of the on/off switch. then the electronics should be able to pull right out. ill take pics of what screws to take out when i get home.
Old 01-12-2004, 09:00 PM
aperson's Avatar
here they are. remove all of the screws in the circles.
Old 01-12-2004, 09:01 PM
aperson's Avatar
and the 2nd
Old 01-12-2004, 09:04 PM
aperson's Avatar
and the 3rd
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
Another Race car added to LP Racing latency ZipZaps 3 10-21-2002 10:03 PM
Built a track, and have some car issues too... latency ZipZaps 9 10-14-2002 01:53 AM
HELP! Car Stutters, etc. DrakZ1 Bit Char-G / MicroSizers 4 09-13-2002 06:25 PM
My Car Doesn't Work Any More CivicMachina Bit Char-G / MicroSizers 3 09-12-2002 10:32 AM
