Old 01-02-2004, 08:36 PM
mattjar mattjar is offline
Neon?
i was wondering if anyone has heard of those HOTWirez made by streetglow and if they could be made to work on a x mods as a undercar kit..........I think it might.... Ill try it out onnly if i find out how much power it drains
Old 01-02-2004, 09:48 PM
Joey's Avatar
Joey Joey is offline
Well they come in three, five, ten, and fifteen-foot kits from $19.99 to $69.99 (according to StreetGlow). Says there that they run on 'low voltage,' but that means something totally different for a full-scale car. They look like they'd make great underbodies, since you can cut them to any length once you get them.
Might just do that.
Ok, I just found out that they use 2 AAs, which equates to three volts. I don't know if I can fit another two AAs under the body, it'd be screamingly tight at the very best.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-03-2004, 02:46 AM
maybe just running it of the car batts...................that probably cause too much of a drain.....i just looked and 2 AAA put of 3 volts im sure you can fit those
Old 01-03-2004, 11:56 AM
Draconious Draconious is offline
Send a message via AIM to Draconious
You also need a large driver box (circuit board) to run the wire... wich is bigger than 4AAA .. they typicaly run off of a 9volt... good luck fitting all that under the body...
Old 01-03-2004, 06:55 PM
Joey's Avatar
Well the Power Paks use 2 AAs. The other ones require a 12 volt power source.
Mazda Savanna RX-7
Old 01-04-2004, 06:10 AM
Revlis Revlis is offline
And dont they also require an inverter or transformer or something? good luck fitting that under there..
Neon Type Snakeman XMODS Mods and Projects 1 11-18-2005 01:49 PM
New idea for neon underglow J-Tuner XMODS 4 12-18-2004 10:12 PM
looking for neon body census007 XMODS Mods and Projects 8 12-25-2003 06:43 AM
)(-Mod Neon Idea xxspeednplayaxx XMODS Mods and Projects 17 12-12-2003 05:04 PM
neon underglow extra lights 2ciz2nv XMODS 0 11-12-2003 09:35 AM
