12-23-2003, 09:02 PM
Spinbrush Installation Tutorial!
after reading the many threads and questions people have on this spinbrush upgrade i've decided that some people in this world are MORONS. for the rest of you here ya go:
Tools needed for installation:
1. soldering iron
2. claw hammer
3. small flat screw driver
Steps for installation:
1. take your SB and KILL IT! all you need is the motor dont worry about the rest.
2. unscrew motor when you get to it.
3. take your small screw driver and pry out the little tabs on the side of the motor so you can slide the plastic piece off the back and toss it (ya dont need it).
4. do the same to one of your regular xmod motor (do it w/ one your not usin first) break the solder points of the capacitors from the motor (so they're still attached to the plactic end w/ the plug)
5. slide the plastic end on the axel of the SB motor.
6. bend the tabs back down to hold the end on
7. solder the capacitors to the sides of the SB motor
8. take pinion from XMOD motor and hold it in a flame for a couple mins. (the heat will expand the brass pinion and not the aluminium shaft)
9. WHILE STILL HOT place motor in claw hammer (so claw is between pinion and motor)
10. GENTLY tap MOTOR (to not mangle teeth on the pinion)
11. line up pinion to the shaft of the SB motor and WHILE HOLDING MOTOR VERTICLE GENTLY tap the motor on the shaft (be sure to not press it all the way against the motor so it will spin freely)
12. BREAK IN! (very important step or your motor can destroy itself)
a. use water dipping method if ya know what it is
b. water dipping:
connect your motor to a power source (battery)
fill a platic cup about 1/2 way w/ water and place motor PINION DOWN so the wires are not in the water (can short out or burn up your motor)
let it spin for about 20-30 mins in the water then dry off completely
13. mount in car and watch your tires go crazy!
Comments:
1. spin brush motor works great (lots of torque)
a. less teeth on pinion = faster accel. (good for driftin)
b. more teeth on pinion = higher top end. (damn fast w/ SB)
2. CHARGE YOUR BATTERIES!
-Toyota Supra
-AWD
-med springs in front
-stiff springs in rear
-4.5 tie rod
-wheel upgrade:
1. racing set (soft treads)
2. drifting set (hard slicks in rear, hard treads in front)
-metal bearings
-top secret motor
-IC-3 batteries
12-23-2003, 11:01 PM
GT3 Drift Master
very nice! very nice indeed! BC! sticky this one!
12-24-2003, 04:43 PM
does the flame thing work? or is it just a guess with the whole brass expanding ?
Supra
-awd
-SB-H
-6 Cell
12-24-2003, 04:47 PM
just tryed it ... didnt work for me
Supra
-awd
-SB-H
-6 Cell
12-27-2003, 02:18 PM
ok i just took the endbell off and the magnet inside is broken in little tiny piece o one side can i use my xmod can and magents or what do i need to do?
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
12-30-2003, 01:31 AM
the heating process takes a while for the brass to get almost to that melting point where its really soft.... be patient its worth it. i messed up a pinion pretty bad the first time cause i was impatent. ill be sure to post pics of the actual process when i do another one (should be soon).
-Toyota Supra
-AWD
-4.5 tie rod
-wheel upgrade:
-metal bearings
-top secret motor
-IC-3 batteries
12-31-2003, 01:18 AM
I broke down and orderd a pinion puller and press. ITS well worth it had it off in 10 sec. and no DAMAGE to the pinon. The puller was 19 bucks shipped.
Im very happy with it. and it makes me want to take apart my electric shaver and see what is inside.
Casey
Supra
-awd
-SB-H
-6 Cell
01-01-2004, 10:47 AM
hey can i borrow that pinion puller ill pay you how ever much cause i need one badly and theres no hobby shops within 60 miles of my house so please?
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
01-03-2004, 10:51 PM
Thanks for the tutorial!
Man I got my x-mod last week and today I did the spin brush mod.
Let me say I can not beleive the difference that it made!
This thing goes faster than my Micro RS4!
Very good easy to follow instuctions.
great Job, now I just need to find that Darn bearing kit that everyone is sold out of.
Thanks Again!
01-04-2004, 10:38 PM
the pinion puller is just a slot car pinion puller which you can buy from www.parma.com or any slot car track..... its way worth having one the old way flame trick works but is hard to do
