11-19-2003, 08:39 PM
SHYMERLOO!!!!
how do i open up a motor?
i want to rewind my motor. how do i open it up?
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
11-19-2003, 09:36 PM
I KNOW NOTHING!!!
COOL you might be the next motor king I havnt done much with motors but I am leaning towards learning a lot more soon.
Here is a link that may help you. carmoworld motor help Check the other help links there also.
To get the endbell off desolder the wires and capacitors from it then very carefully bend those little tabs on the endbell out straight and carefully pull the endbell off.Watch for washers falling as the brushes tend to drag them off.
11-19-2003, 10:03 PM
SHYMERLOO!!!!
i cant get the gear off the motor...
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
11-19-2003, 10:08 PM
0reZepyT
you need a pinion puller to safely take it off.
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
11-19-2003, 10:10 PM
SHYMERLOO!!!!
i dont have one
what else can i do?
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
11-19-2003, 10:17 PM
I KNOW NOTHING!!!
DOH I forgot the pinion puller, the one thing I will be looking for locally thursday.
I tried two flat screw drivers but it just slid the windings on the shaft, the pinion puller is the only good,safe way.
EDIT: You know if you really dont care about the pinion at this time you could cut it away or file it down to get it off. Just use a stage one stock motor and at least you will be able to tinker with the armature.(just a thought)
11-19-2003, 11:06 PM
i believe u can just heat the gear up an pull it off
11-20-2003, 12:28 AM
Perfected Bit Modder
nope dosn't work..i tried heating it up to about 1600f deg and it didnt work
11-20-2003, 10:37 AM
Re: how do i open up a motor?
Why do you want to rewind the motor? If you don't know how to open one up then chances are your inexperienced to rewind the armature. What is it your trying to do?
On another note...if you have access to an arbor press(cheap at supply stores) you can get the pinion gear off by supporting the bottom of the gear, insterting a pin just smaller then the diameter of the armature shaft and pressing it out.
Why do Xmods use brass pinion gears and Mini-Zs use plastic?
11-20-2003, 01:33 PM
Got Brains?
Sluggbug
thanking site for link you. picture may many helping. hurting english on page site.
