Old 10-08-2003, 08:44 PM
Bad Company's Avatar
How to make body kits (skirts).
This is how I do it anyway.
You can do this one of two ways, depending on whether you have a dremel or not.
Things you will need:
Styrene sheet. (Thickness up to you.) (I used 3 sheets of .30)
Glue (I prefer Krazy Glue.)
Dremel or Scissors
Pen or Pencil
Sandpaper
Lay you body over the sheet of styrene. Trace out the edges of you body, the front, rear, left side, and right side. You can save space and styrene by picking up your body and tracing like in the pic. Leave a little space around each one, you will see why in the next step.
Old 10-08-2003, 08:45 PM
Trace like this to save space. Again, leave a little room around each.
Old 10-08-2003, 08:47 PM
Next, draw a little extra around the body lines, more so to the outside. This is your overhang, so make it however much you want. Leave a little bit to the inside, this assures you have enough to glue it to the bottom of the body.
Old 10-08-2003, 08:51 PM
Keep in mind you will be glueing multiple sheets together to obtain the thickness you want.
At this point, you can do it two ways. You can cut these out now with scissors, lay them over another piece to trace out your next layers, or you can glue your sheets together under your tace lines, and cut it out at one time, but you will more than likely need the dremel for that due to the thickness.
Old 10-08-2003, 08:53 PM
Depending on which way you did the last step, you will already have your skirts ready to mount, or you will need to glue the individual sheets for each side together.
Old 10-08-2003, 08:57 PM
Lastly, you will glue your pieces to your body and start to shape them with your Dremel and/or sandpaper. From here you can do whatever you want. You shave/sand them down to the desired amount you want them to overhang, and you can round the edges, and smooth. After that, you are ready to paint.
I make mine wide like this, and then sand them down to where they look good.
Old 10-08-2003, 09:01 PM
Don't forget to sand away the inside too to make room for the body to fit over the chassis.
Old 10-08-2003, 10:06 PM
itsalllies's Avatar
itsalllies itsalllies is offline
bite my shiny pimpmobile
nice when I find the stuff I need I will do it to my skyline and paint it black
Old 10-09-2003, 12:52 PM
zzmaniac zzmaniac is offline
Very nice job BC. Thanks for the how to. This should be made sticky.
Old 10-09-2003, 01:46 PM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
Thumbs up
Great tutrorial Bad Co.! Nice illustration
Old 10-09-2003, 02:10 PM
denden's Avatar
denden denden is offline
Mini Rc Enthusiast
Excellent Pictorial !!!
Old 10-09-2003, 02:29 PM
viperkilla's Avatar
THANK YOU!!!!!!!!!!!!!!!!
Finally i know how to make skirts. Thanks Bad Company. Muhahahah time to mod my Savanna.
Old 10-09-2003, 08:04 PM
And once you smooth the edges and paint it...
Old 10-09-2003, 08:27 PM
itsalllies's Avatar
all props to you if we made a king of zz/se you would win in a heart beat Evos sick
Old 10-21-2003, 05:11 PM
lancer11's Avatar
lancer11 lancer11 is offline
Pimpin'em Hoes
Send a message via AIM to lancer11 Send a message via Yahoo to lancer11
where do u get stryene i have looked but i cant find it anywhere
Red metal flake civic project tons of upgrades
Body kits?..How do you make them? N2O ZipZaps Gallery 0 03-14-2004 04:54 AM
Body KIT's? Body Flares Suntzu28 Bit Char-G / MicroSizers 1 02-12-2003 11:13 PM
Body Kits EvolutionR28 Bit Char-G Mods and Projects 21 01-17-2003 03:51 AM
Body Kits ndto Bit Char-G / MicroSizers 2 09-11-2002 03:33 PM
Body post Modification DAMZer ABC DTM Parts and Hop-Ups 2 08-25-2002 10:07 AM
