  #46
Old 09-11-2003, 12:09 PM
Bad Company's Avatar
OK, It wouldn't let me edit the last photo, but anyways...
I trimmed the skirts down and added to the spoiler. I just need to fill in the cracks with putty. Next step.....tab lower that SE chassis.
Old 09-11-2003, 12:28 PM
Here is a pic of the body on the chassis lowered. There is not much lowering capablitlies on the SE chassis, with or without the lights PCB board in the body. The main problem is that bigh ole black box on top of the chassis PCB.
Old 09-11-2003, 12:30 PM
Here is a comparison with a normal SE chassis. The SE chassis still has the lights PCB, so without that, it could be a tad lower.
Old 09-11-2003, 01:02 PM
dr1zz's Avatar
dr1zz dr1zz is offline
phear meh..............
that looks alot better than stock!!
good work!!
Old 09-11-2003, 04:09 PM
ron6 ron6 is offline
hey Badcompany can you tell me how you made the bottom part of the car and the fin and what did you use to make it and what are the mesurements of it the way it looks is great i would like to have that design on my zipzap if that is ok with you
Thanks
Old 09-11-2003, 04:18 PM
I don't mind if use it at all, it's not trademarked.....yet. I used styrene sheets and stacked and glued them together. You can use either (3) 20mm sheets or (2) 30mm sheets to obtain the same thickness I have or make you own thickness. I traced the pattern around the body, and did the same for the spoiler, but made that a little larger. I make everything a little big and then sand it down after it is glued to the car.
Old 09-11-2003, 04:20 PM
airline2's Avatar
airline2 airline2 is offline
I Love Xmods
i think that is not lowered
Current Xmods Setup
Old 09-11-2003, 04:33 PM
It is...
Old 09-11-2003, 04:34 PM
airline2's Avatar
I Love Xmods
they look they are the same height
Current Xmods Setup
Old 09-11-2003, 04:35 PM
ron6, this is the best I can do on my home computer. No Auto Cad here. Theis will give the basic dimensions and you just have to shape it to the contour of the body. Mount the side skirts flush to the inside of the body and mount the front and rear to have the same outside overhang as the side skirts.
Old 09-11-2003, 04:38 PM
Look again....
It's not much, but it's the lowest you can go without removing the LED PCB.
Old 09-11-2003, 04:55 PM
Hey bad company thanks for the pics and the dimensions can you tell me where you can get styrene sheets or do you think you can make the parts and mail them to me i would really appreciate it if you can my address is 2579 jenna lane lithia springs GA, 30122.
Thanks
Old 09-11-2003, 04:57 PM
Yugo DSC Maxxer's Avatar
Yugo DSC Maxxer Yugo DSC Maxxer is offline
Zip Zap SE Basher
Send a message via AIM to Yugo DSC Maxxer
That is nice, Bad Company....
The stock SE looks like an Off-Road vehicle!
My Bit Char-G (Currently dead): and a Perfection 4.2....There really needs to be an icon for the 4.2's.
I got a Zip Zaps SE!!!
Yay!
Old 09-11-2003, 04:59 PM
You can find styrene at you local hobby shop. Now, if I made them for you, that would take all the fun out of it, and the feeling of accomplishment you your part. It's really not hard.
airline2:
The car is more lowered in the front than the rear because of the black box on the PCB, and the skirts do give it more of a lowered look, but it is lowered and makes the profile look a lot better than the original which had the body leaning towards the rear.
It will get dropped more once I remove the lights and figure out what that box is and if anything can be done with it.
BTW, I stuck some better photos in the Gallery Forum.
Old 09-11-2003, 05:05 PM
airline2's Avatar
I Love Xmods
when i get mine tommorow i will keep the body stock
Current Xmods Setup
Hey, thinking about x mods Metallica88 XMODS 7 02-16-2004 01:16 PM
step by step how to for mods Twistid ZipZaps 2 12-27-2002 03:03 PM
some questions on bit char-g mods eman1 Bit Char-G / MicroSizers 29 12-17-2002 08:27 AM
Anyone Found any "Do It Yourself" Mods for ZipZaps? hawks10 Bit Char-G / MicroSizers 6 09-25-2002 11:41 AM
Got my bit, what are some good mods? Chronic Bit Char-G Mods and Projects 3 09-14-2002 10:39 PM
