03-03-2003, 10:34 AM
If you run your car on smooth garage concrete, use Simple Green all purpose cleaner. Dilute it in a spray bottle with 50% water. You can either let it air dry or wipe it off the concrete. Either way, the tires will bite hard! Only downfall...If you try to turn, you'll just tumble.
03-04-2003, 10:50 AM
Internet Web Ninja
I would like to see some photos of the tires on or off the car please.
Thanks!
03-04-2003, 11:21 AM
smoove operator
Originally posted by Zephyranthes
Swiffers are a good way to clean your floor of dust. I did it to my floor, and there was hardly any crap on my tires.
Hell yea! those are the best things since 'sliced bread' lol
Thanks!
I posted a size comparison HERE.
left to right;
Pullback Rear--->Pullback front on Bit knuckles--->regular Bit front
03-04-2003, 12:00 PM
i have rear wheels off 2 pullbacks on my car so they are the same all round
04-01-2003, 09:31 PM
Rice Me
swiffers kick ass.... that's all i have to say about this.
06-24-2003, 04:09 PM
Cuttin' up Daisy
06-25-2003, 01:31 PM
Cuttin' up Daisy
ok, i swapped the back tires too.
before this the car would flip on turcs, now with all 4 pullback tires it STICKS to the ground!  and it doesn't do donuts either! so i would recommend this mod to anyone getting a pullback.
and if ur pullback does nothing but donuts, don't bother with the trim, remove the front tires.
06-25-2003, 01:34 PM
Cuttin' up Daisy
by the way, my pullback is faster than my bit 3.0
07-31-2003, 01:12 AM
Got 4.2 King? I do : )
do the pullback tires have to come off the axle of the pullback or does the axle just transfer over
i'm thinking of ordering the new r34 skyline pullback, perfection 4.2 and a 200mah batt. that would be crazy fast
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
08-01-2003, 10:26 AM
Cuttin' up Daisy
Micro,
The axles are not transferable, the tires are not meant to be transfreable, but they can be transfered. The tires need a bit of stretching to go over the standard bit rims. Some guys have swapped standard bit rims with pullbacks , the smaller wheels lower the bit, and the wider rims also makes the bit harder to flip (from what I've read).
If your going to swap tires, be sure to remove the tires when not in use, i left em on, and now one tire has split  , but only after like 2 months stretched over the bit rims. Guess i just have to get me a new pullback
