Old 01-24-2003, 02:13 PM
timisone
Anybody know if the 4 band controller
does it have a criple cap
Old 01-24-2003, 03:03 PM
bill's Avatar
bill bill is offline
I are smart....
No, it doesn't have one. Well, it has never been found yet.
Old 01-24-2003, 03:04 PM
timisone
then why does the range suck
Old 01-24-2003, 08:53 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
I put a radio shack $3.69 antenna in my 4 band. Range increased a great deal (didn't do any actual measurments). Part number is 270-1409. I can put up a pic if interested. It was real easy to do, no soldering, just trim a little plastic. Controller does have a lot of loose pieces if you try to open it, so beware.
That's all folks!
Old 01-24-2003, 09:02 PM
timis2's Avatar
timis2 timis2 is offline
yea can u post pics for me
Old 01-24-2003, 09:28 PM
timis2's Avatar
u think you got ten feet
Old 01-24-2003, 11:17 PM
bdebde's Avatar
That's all folks
Here is a pic of the controller with new antenna. I drilled a hole in between the holes already on the antenna base. I took out the screw that holds the little clip that the wire runs through and screwed the antenna down right on top of the clip. You have to remove the wire antenna, I just took out the roller and folded the tip of the old antenna below where the roller screwed on, then put the screw back in to hold it down (without the roller). You have to trim off the little tab of plastic on the case that protudes to fill the antenna hole, and then carve out a small notch to fit over the base of the antenna.
Old 01-24-2003, 11:21 PM
bdebde's Avatar
That's all folks
Here is a closer one.
That's all folks!
Old 01-25-2003, 10:49 AM
timis2's Avatar
thanks how long of distance do u think u get.
Old 01-25-2003, 09:48 PM
bdebde's Avatar
That's all folks
About 30 feet, some cars are less, some are more.
That's all folks!
