Old 01-04-2003, 11:45 PM
isk8blind's Avatar
isk8blind isk8blind is offline
isk8element too.
Send a message via Yahoo to isk8blind
how to make my micro pull wheelies?
ne1 have some mods or parts i should use to make my skyline pull wheelies
Old 01-04-2003, 11:47 PM
Impreza WR reX's Avatar
Impreza WR reX Impreza WR reX is offline
<(- -)> <- Yoda
either add some wight to the back or do a dual cell mod
wooo hooo!
Old 01-04-2003, 11:53 PM
ShadowMage's Avatar
ShadowMage ShadowMage is offline
Box Racer
Send a message via ICQ to ShadowMage Send a message via AIM to ShadowMage
or get a the Panda NSX-R BCG set. With that zz turbo motor I was able to pop wheelies with no extra weight in the back and (other than the engine) totally stock.
Underground Dweller: If I were you, I'd start running!
Buddy: If you were me, you'd be good lookin'.
--Quote from Six String Samurai
Old 01-04-2003, 11:55 PM
isk8blind's Avatar
isk8element too.
i do
i do have a zz turbo it makes it pop a liitle but for like half a sec.
Old 01-04-2003, 11:58 PM
ShadowMage's Avatar
Box Racer
Yeah I kinda guessed that you had that since you posted your setup in your first message.
Ah so you're wanting to pop wheelies for extended periods then...weeeeeell...then listen to Impreza WR reX
Old 01-05-2003, 12:37 AM
mrcdemon
wrx is right. dual cell mod would be a good way to go... plus u get more runtime
Old 01-05-2003, 08:42 AM
Swavey's Avatar
Swavey Swavey is offline
Got Avatar?
a controller weelie would look sooo cool!
at the moment with my bit, i cant only get about .0001 second welie action unmoded.............workin on it
Old 01-05-2003, 09:07 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
pics of my dual cell mod
i wish i could use the IMG tag in signatures....
Old 01-05-2003, 09:08 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
after smoothing all the stuff out of it and removing the metal charging bits.. do this..
Old 01-05-2003, 09:09 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
as u can see they extend the full length of the chassis now.. next stpe make the batt pack
Old 01-05-2003, 09:10 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
i soldered a thin piece of metal to the other end and insulated it with electric tape. now put it into your chassis with the pos side to the passenger
Old 01-05-2003, 09:12 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
of course that pic dotn show it too well but thats b/c i had them in upside down tape goes up now you have yer batts in.. now tape everythign together as now your pcb cover wont fit.. make sur eno metal is touching metal.. u may wanna cover your heat sink with some tape and tape down yer batt pack so it wotn move around..
Old 01-05-2003, 09:14 AM
jei$'s Avatar
jei$ jei$ is offline
what tires are u using to make it pop?
hard dont work
A man who desired nothing is invincible.
Old 01-05-2003, 09:17 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
after tape
Old 01-05-2003, 09:19 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
with body damn sweet handling too b/c the center of gravity is moved down (compared to some other dual cell mods) also its centered so no wheelies it just hauls ass and hardly flips.. itll do tight lil circles faster than anything..
My Custom - Micro T + Case + Ramps nazcom_101 Micro-T General 8 11-30-2007 04:56 AM
Make your own composite sheets. bizzybody Bit Char-G Mods and Projects 0 04-05-2007 05:15 AM
How To Build a Micro Speed Control From a Servo Overlander TTTT 20 05-26-2004 12:21 AM
an idea on how to make your xmod do real wheelies!!! cyrc XMODS 9 11-23-2003 01:35 PM
Canadian Micro Grand Prix lornecherry Bit Char-G / MicroSizers 9 10-03-2002 01:36 PM
