08-17-2002, 03:44 AM
does the hot wheels KIT come with stickers? the bit racer in the shop here says that it comes with stickers
08-17-2002, 11:39 AM
323it, yes it does.
08-21-2002, 12:13 AM
I'm with stupid^
i jsut bought one of those KIT racers at target. $12.99. They're pretty cool. the set is made by tomy but lisenced by Hot wheels, i'll post sum pics next time.
08-21-2002, 12:18 AM
I still don`t see any pictures?!?!?!??!?!??!? lots of talk but nothing else...............
If you get upset with life eat your favorite yummy food
08-22-2002, 11:17 PM
Picked one up but...
I'm not sure if I want to open it. A lot of useful parts in here including, of course, the 2.6 motor. There are 6 models, but I only found 4. Two had the 2.2 motor, two had the 2.6 motor.
Parts that can be reused in the Bit Char-g include:
- the motor (2.2 or 2.6 for now)
- heat sink
- battery
- tires (but they are either white or orange and only rear ones)
- rear axle (with some modifications can work)
- charger (although the contacts are spaced differently and only charges for 30 seconds)
Here are the pics:
08-22-2002, 11:54 PM
Bit OG
where does it say its a 2.2 or 2.6? cuz im thinking of buying a kit. theyre like 13 bucks. a 2.6 around where i live is 7.50, a bit racer bumper set, is 7.50 too. So i might as well buy that since i get a couple extras, including the battery. I guess the next time i want a 2.2/2.6, a battery, and bumpers, im just gonna buy this kit. I might buy this pretty soon so i can make a monster truck.
08-23-2002, 12:38 AM
Yellow is the 2.2 and Orange is the 2.6. Just look at the color at the end of the motor in the package. On the back it says M-1 for the 2.2 and M-2 for the 2.6.
08-23-2002, 02:05 AM
I found the KIT Racer at Target.
And picked one up, it came with the 2.6 motor, axle with the green gear, the green 3.43:1 transfer gear, and a white pinion gear.
Things to note:
- The black pinion gear that comes with the Char-G does NOT work with the above transfer gear (the teeth do not mesh together).
- Above transfer gear is MUCH smaller then the stock Char-G transfer gear so it doesnt reach the stock Char-G axle.
- You need to shave the inside the axle down to fit inside with the Char-G. The rims seem slightly larger as well then the Char-G axle.
After installing all the above parts into my Char-G it barely moved. I ended up using just the motor from the racer with the stock pinion, axle, and transfer gear that came with my Char-G.
