Old 12-30-2002, 11:05 PM
shocon2k
Shen gearing...
My shen doesn't like taking my BCG motor (with either the bit pinion OR the shen one) or my BCG gearsets...whats the deal? Should I try the 7 tooth pinion or what? The mesh is so tight when I put in my other gearsets that its hard to even turn by rolling the axle with my fingers.
Anyone else with shens please post about your gearing and if it was possible for you to change the setup. Thanks guys.
Old 12-30-2002, 11:12 PM
Ripper720's Avatar
Ripper720 Ripper720 is offline
Assembling a CLONE army..
hmmm very strange, I have no problem changing gears/motors with my Shens and MSizers. Though I find the Shen Motor out performs the MSizer. Let me know what you find out. Sorry I can't be of more help.
RIP
Old 12-31-2002, 01:28 AM
takumi_drifto's Avatar
takumi_drifto takumi_drifto is offline
DriFt OnLi
Send a message via AIM to takumi_drifto Send a message via Yahoo to takumi_drifto
i ordered a 3.8 motor for my shen.. and im about to get gears. HOPEFULLY they will work.
DriFT_
Old 12-31-2002, 06:43 AM
bitchar-gmotors bitchar-gmotors is offline
shocon2k,
You can tighten up or loosen up the gearing a little by rotating the motor in the compartment. If you place the the motor in with the metal tab toward the front of the car, it will push the pinion gear away from the chassis gear a little freeing it up some. If you place the motor in with the metal tab toward the rear of the car, it will press the pinion gear toward the chassis gear and tighten things up. I hope this helps you out. I haven't had this problem with my Shen car. I just pop in a 3.8 and zoom zoom zoom.
Kyle
BITCHAR-GMOTORS.COM
Need Help With Shen BigPappaBuck Bit Char-G Mods and Projects 5 03-20-2003 05:13 PM
Shen Vs. Precious sessiz10 Bit Char-G / MicroSizers 41 02-04-2003 02:14 PM
Ordered Panthers, go Shen Qi Wei's.Which is better? AznMidnite Bit Char-G / MicroSizers 29 01-03-2003 11:31 AM
Special editon gearing vrs normal gearing Smurf Bit Char-G Parts and Hop-Ups 2 10-09-2002 11:08 AM
