12-04-2002, 12:01 AM
323it i tried drifting a skyline with the stock medium tires on all corners, wit a 3.8 motor... Guess what happened... U cant drift lol. Itz really hard the best i can do is whip the car around. Ive got it to skid a turn but then it spun out when it came outta the turn so that sucked.
12-04-2002, 12:04 AM
Also i just got a new loctite and pennzoil. Itz impozzible to drift thiz cuse the rubber wont skid on my tiles. Too bad i dont have hardwood. I skidded mine on a trak at my lhs.
12-07-2002, 11:04 PM
Our whole downstairs is hardwood! All I have do do is use some cleaner and clean a bit of it and I can drift all day. I have a track set up down there. It's great!
I need to get it on tape because it looks awsome!
12-09-2002, 02:32 AM
2.2 motor
stock stabilizer
orange gears
medium tires on both front and rear
dual batt mod
its a good drifter, u cant do it at top speed or the thing flips over so i just accel let go tap opposite direction and then to the direction of the turn while tapping the accel
IT EVEN DRIFTS ON CARPET!!!!!
12-12-2002, 03:52 PM
www.d1gp.com
heya guys i think i figured something out, but not that important...
since ive been using full size ZZ rims on my bit, ive always used full size tires...and i noticed that i had some soft front tires left over, so whati thought to make lowprofile tires, is to put the small front tires on my car..and for some strange reason, it makes me drift better....but it maybe just me...
my current setup was:
no stabalizer
hard ribbed rear tires, or medium tires on the rear
soft small front tires on full size rims on the front
red ZZ gears
2.6-3.8 motor
and using my lowered/lighter skyline body
i was actually amazed that my skyline went straight...because normally it would venture off to the side when i put it in the new front slot to lower it...i think the overstretched tires helped out alot..
12-15-2002, 11:38 AM
Yokohama Skyline
I drifted!!!
Setup
Kit racer Green gears
Nos motor
ZZ front wheels
No tires
Hard suspenion
12-15-2002, 05:02 PM
hey yo... driftin is something i would love to do in real life, but me and my friends settle for just driftin with our bits. i use a really simple set up.
R32 Skyline from the History of GTR set
BitRacer 3.0 motor
BitRacer Soft front tires
BitRacer Hard rear tires
and thats about it...
my friend uses a the same except for the body... its a lancer. try these setups out and get back to me with ur results...
oh yea try to drive it on tiles that arent too dusty cuz its just a really big hastle to clean your chassis and tires. a little bit of dust helps, but too much just makes you spin out a lot easier.
12-17-2002, 08:35 PM
DriFt OnLi
MTL.. is that a sil-80 on ur icon thing?? does Bit Char-g make silva's?
12-18-2002, 06:49 PM
www.d1gp.com
yep its a sileighty
tomy doesnt make a bit one
i actually sorta DID make one out of an rx7 body with putty, but umm....sorta messed up when painting and stuff....got lazy, threw it away...
i need more bodies ;/
12-21-2002, 10:26 PM
Microman to the rescue!!!
Ok i need to know what i need to be able to drift. I bought the tune up set from here and it says it comes with a drift axel, so what do i need to do with it just put it on the car and, well, i read that you use the suspension arm with 2 holes. Then what? Hope you guys could help, thanks. I also would like to know, what you have to press, as in on the controller, to be able to drift, thanks.
**EDIT**
Oh yea, and when i look at the regular rear axel, on the rims it has 1 line in the middle, and when i look at the Tune-up set back axel rims it looks all rigid and everything, whats the difference? Thanks.
12-23-2002, 12:54 PM
Sangru Lava U Sangru
dirty lynoleum floor does it for me.........
all i do is make sure there is nothing that will get caught up in the gears on the floor, then i drive! thats it, the car is regular setup and everything stock..... maybe it'll work for yall......... l8r
12-23-2002, 08:02 PM
video link
chassis=Tomy 35 MHz 2-Spd
body=Silver Nissan 350Z
motor=ZZ NX
(Lambo set in the mail)
12-25-2002, 04:21 AM
Got Mini-z?
how can i drift???i have all the mods that u can buy from microsizers except the speed thingy and engines...i still have the stock engine and all...wa should i do that dosn't make me have to buy anything else?
12-26-2002, 02:45 PM
Sorry to say this but yo need a new and faster motor.... Um try this if it dont work get a faster motor its only like 10 bucks not that much! Ok get down to buisness take out you back tires=drift axel now!!!! Ok then enter a turn pull the other way of the turn then QUIKLY PULL BACK IN
I think that is how it works but I dont know for sure! Just do anything thats possible and remember practice makes BETTER!
WRXin'
01-12-2003, 06:21 PM
Got Mini-z?
ok..now i have a 3.0 motor ..it dosnt help at all..i just keep on doing donuts with tires on..and my soft tires are too griip but my medum are to slick
