Old 11-08-2002, 06:04 PM
cowfish_29's Avatar
yellow fish forever!
some necklaces are very rigid rotationally yet are flexible in all directions...why not use a link from a cheap necklace as a u joint.
that might be exactly what you need! That is such a good idea i might have to do it myself.
Old 11-08-2002, 07:58 PM
Paintballa Paintballa is offline
FunkMasterFlex #13
Send a message via AIM to Paintballa
well i'm officially scared lol. i had no idea how huge these things really r u guys r just blowin my mind with all this. i'm glad i found this place i hope i can learn alot from all u guys.
a vote for turd sandwich is a vote for the future- south park
Old 11-10-2002, 09:06 PM
ketis
you can put treads on ur car which will drive ur front and rear and get 2 motors and put one motor on the treadnear the front tire
Old 11-12-2002, 06:35 PM
Short1mgb's Avatar
Short1mgb Short1mgb is offline
Lets Play Some Tetris
that was my first idea but because of the suspension and steering magnet its impossible
Old 01-23-2003, 05:54 PM
maddog90008 maddog90008 is offline
Hey, I was reading your thread and I plan on doing a 4wd (2 motor) conversion for my bit as soon as I order my two speed bit. After that I will try it. I'm converting a bit to fit into a skyline muscle machines import tuner body. I have a pretty good idea how to get the front motor to work with the front wheels turning. I think I can make this work. I'll let you'll know my plans as soon as I get then drawn up and make sure it will work. Also, if anyone knows anything about electronics
I would like to know:
How do you wire one battery powering one motor and another battery powering the other motor for when you press forward or reverse they will both go respectively in the same direction?(hope that made sense)
Then after that would they both still charge on a stand alone charger or would only one battery get juice?
Some please let me know because I am trying my idea very soon.
Old 01-24-2003, 01:16 AM
frizzen frizzen is offline
Tool User
The necklace idea for U-joints would work pretty well if you can find the right "box chains". They ought to be dirt cheap if you get them through the right place. If you cold-solder (lead) a couple joints at each end for connection points, it should work perfectly Anyway, you may still run into problems with turns since there's no diff.
Maddog,
Just wire the entire (dual motor, dual battery) circuit in SERIES, but make sure that your contact points for the motors are wired up so they spin properly for your setup.
Old 01-24-2003, 03:42 AM
met-sb
4 wheel drive?
maybe if u mounted a motor independently on each wheel
tha twould work good
Old 01-24-2003, 01:45 PM
Hey all,
I started working on my conversion last night. I almost have the rear motor mounted and ready to go (The easy part). Soon I'm going to start working on the front. I have to build everything from scratch pretty much (insides at least) but one problem came up last night for the rear wheels. They spin, but not as freely as I want them to. I think I'm going to add a "spring suspension" (it not true spring suspension like the front could be, but I am going to use springs) for the wheels so they have enough clearence from the fender wells. What do you'll think?
Entire Bit collection for Sale (Customized Bits) bitfreak Bit Char-G / MicroSizers 10 09-13-2002 07:28 PM
