Old 07-02-2006, 12:26 AM
moebrown20's Avatar
moebrown20 moebrown20 is offline
Send a message via Yahoo to moebrown20
Originally posted by eetoi
but will it work for Evos?
Yes, they will work for evos
Drivers Wanted.
Old 07-02-2006, 09:53 AM
bengali548's Avatar
bengali548 bengali548 is offline
(insert something funny)
fo the evo do you have any pics of what the forward fet is and the reverse fet is
Old 07-27-2006, 04:29 PM
bengali548's Avatar
k i acidentally installed the 7329 fet in the 9910 spot and i still was able to steer that means electricity was flowing through my xmod so instead of taking out the 7329 shud i just leav it there and install the 9910 in the 7329 spot
oh also just wondering could i stack 3 9910's with only two 7329's
Old 09-09-2006, 06:25 PM
skidmark skidmark is offline
Fet Mod Schematic and Layout
Hey all,
I'm new here but I just wanted to share this with y'all. This circuit is basically the same one RacinSkillZ101 posted some time ago and also the same circuit as Neuro's except with a 5v regulator. Anyhow, I made a layout and schematic for it so I could attach it to my xmod and thought I'd post it in case anyone was interested.
Some points of interest first:
1) I've flipped the Fets sothat they can be flattened against the board heatsink up. This is so I can blow air from an intake over them.
2) The IRF's are 4905's, IRL's are 3705's and the regulator is a LM7805.
b=battery
m=motor
and the -# after the IC's is the pin pad to connect to.
Old 09-09-2006, 06:31 PM
Here's the Layout
Insert this layout gif into a word doc and resize it to:
W=1.36"
H=2.23"
Then get a sheet of labels, peel off all the labels and print you doc onto the shiny side of the sheet with a laser jet printer. Then you'll be able to transfer the circuit onto a blank PCB with an iron. Notice the image is inverted.
Old 09-09-2006, 07:06 PM
BTW
cc+ and cc- are power and ground for the xmod's circuit board.
Old 09-10-2006, 11:59 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Very good and thorough info! Thank you very much.
Old 09-12-2006, 06:30 PM
Woops
This is the corrected PCB layout...sorry bout that.
Old 10-16-2006, 08:53 PM
RacinSkillZ101's Avatar
RacinSkillZ101 RacinSkillZ101 is offline
Banned
Send a message via AIM to RacinSkillZ101 Send a message via Yahoo to RacinSkillZ101
hey nice work, im going to receive some money from school later in the month, when I do I will pick up an EVO xmod, no mods just want to get back to driving these things, I will test out my frankenstein electronics, vids to come once the winter months roll in.
Old 08-18-2007, 07:18 PM
fatman's Avatar
fatman fatman is offline
yes
it is the riite layout
if its not broke i can fix it
Are lipos and FETs worth it? Answer here Jazz32 XMODS Parts and Hop-Ups 24 10-29-2006 09:54 PM
Stock FETs max Amps? 4Runner XMODS 2 05-03-2005 11:53 PM
iWaver PRO FETs Revealed! aaron Mini-Z - Mini-ZRacer.com 0 12-17-2004 09:33 PM
Smoking Xmod!!! 4562 fets? chc XMODS 6 09-21-2004 02:42 PM
Xmods Video MicroRCEngineering XMODS 10 01-24-2004 11:39 AM
