Go Back   TinyRC.com > 1/64 and Smaller > ZipZaps, ZipZaps SE > ZipZaps Mods and Projects
Old 04-13-2006, 11:58 AM
hschnark hschnark is offline
Gluing Gears
Has anyone found a way to glue ZipZaps gears together to make compound gear sets? They appear to be Nylon or something similar and CA, Etc. does not work well.
Thanks,
Hugo
Old 04-13-2006, 04:03 PM
chilli_mp138 chilli_mp138 is offline
perpetual newbie
hschnark:
Yes, I have. I have rebuilt gears with success by abrading the surfaces and joining them with CA.
chilli
Old 04-13-2006, 04:34 PM
Thanks Chili,
That's what worked best for me also but I was hoping there was something better. It doesn't always hold.
Hugo
Old 04-14-2006, 12:07 AM
ibjamn's Avatar
ibjamn ibjamn is offline
Talking
yeah, luckily it doesn't! my fingers are thankful for that! jk
have you tried JB Quick? I've used JB Weld to hold a magnet unto a driveshaft before......
Old 04-14-2006, 03:53 PM
ibjamn
Do you mean JB Kwik, the fast setting Liquid Steel/Epoxy mix? I haven't tried any epoxies. Do they work on Nylon?
Hugo
Old 04-14-2006, 10:27 PM
ibjamn's Avatar
I would assume so. Another forum/site has a tip on using it at the rear axles (bits & ZZs) to repair the plastic slots that the axles snap into. If it sticks to that , I don't see why not. And since it is thinner, it should not add to much rotating mass.
If it was me, I would scuff up the gears w/ sand paper and use CA.
Old 04-15-2006, 08:34 AM
Thanks ibjamn,
The scuff it up & CA is the best method I have found so far but it only holds about 2/3 of the time so I am looking for something better. As for the chassis, it is molded from something different than the gears and CA and even good old Testors plastic cement works there.
Hugo
Pinon gears. dje7447 Bit Char-G / MicroSizers 7 10-09-2003 03:52 PM
Tips for quieting gears NoPropMan Bit Char-G / MicroSizers 14 03-27-2003 11:59 PM
K.I.T. gears = stupid Zephyranthes Bit Char-G / MicroSizers 4 03-14-2003 12:59 AM
clone gears vs bit gears ? Mike the Great Bit Char-G Parts and Hop-Ups 10 01-19-2003 01:05 AM
loud gears?? streetrage Bit Char-G / MicroSizers 6 12-16-2002 11:11 AM
