Old 02-06-2004, 10:44 AM
Rez Rez is offline
Low Voltage Warning Light
I found a schematic for a low voltage warning light system. Two LEDs come on when the voltage drops below a given amount. This is good because the car wouldn't suddenly stop when the voltage dropped. In stead you could finish a lap or drive to the "pits" or what have you. It should be fairly simple to modify this circuit to a cut off if that's what you want. Check it out
http://homepages.paradise.net.nz/bhabbott/lvw.html
Rez
a7i20ci7y
Seven Cities RC
Old 02-06-2004, 11:28 AM
RC 2NR RC 2NR is offline
TinyRC XModder
Looks interesting..I'd like to see how this works out for someone.
BTW, Rez your sig is hillarious.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-06-2004, 11:32 AM
bob256
Hmm...., well that a lots simpler than what i had in mind, i was going to use the a/d of a PIC and monitor the voltage, then shut down within a certain range, if i have time i'll try to mock up the circuit on a proto board
Old 02-06-2004, 11:42 AM
Rez Rez is offline
That would be awesome. I'm no electrical engineer, so I have no idea if this guy's rig will even work
Glad someone got the joke, 2NR
Rez
a7i20ci7y
Seven Cities RC
Add light set to your non ZZSE bodies! 'Vette Nerd ZipZaps 1 08-29-2006 04:18 PM
need some info about light kits bengali548 XMODS Mods and Projects 3 08-02-2006 11:44 PM
Low cost, light weight, cheap.... Comrade_Boris XMODS Gallery 22 07-13-2004 09:51 PM
Micro low voltage relays. bdebde Bit Char-G / MicroSizers 5 04-30-2003 12:00 AM
Help with head/tail light installation BCGMan Bit Char-G Mods and Projects 10 01-04-2003 06:39 PM
