Old 12-30-2003, 11:16 AM
matrixled
Thanks
What did you ground Pin1 (IC5 0r IC6) to?
Old 12-30-2003, 11:40 AM
neurokinetik's Avatar
When you remove IC5 and IC6, you can see a big fat trace underneath them that was connected to pin1 on both chips, and is grounded.
If you attach to either pin 1 trace, it will ground the circuit. Alternatively, you could connect the wire to where the - battery wire attaches to the board.
Old 12-30-2003, 01:44 PM
LithiumXmod LithiumXmod is offline
Just finished wiring the grounds of the fet's to the battery. I cannot really tell if it made a differences.
LithiumXmod
Mods:
4 Cell CR2's Photo Lithium Batteries
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Suspension - Front: S Rear: H
Steering - 1.5 degree Tie Bar
Coming soon:
Ball Bearings
Old 12-30-2003, 03:33 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i'm sure you'll see a difference once you move up to high current draw motors....the difference being the fet upgrade can handle it while the stock fets simply melt
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-31-2003, 09:36 PM
Well, I now have the FET circuit hooked up this way. I thought it strange that LithiumXMod said that it didn't work, so I decided to try it myself. It actually does work, and now the only connections that need to go to the main board is the gates of all four MOSFETs. The rest of the connections are on the standalone PCB. Even a Plasma Dash wouldn't kill this setup now. Actually, even a Novak SPY can't handle the current that this setup can.
Old 12-31-2003, 09:45 PM
rmyc's Avatar
rmyc rmyc is offline
Perfected Bit Modder
haha sorry but i dont get the diagram.. which prongs attach to the esc?.... thanks
Old 12-31-2003, 10:26 PM
Just ignore where all the lines cross unless there is a dot at the junction.
Basically, it works like this:
Connect the sources of both IRF4905s together, and then connect them to the positive (+) battery terminal.
Connect the sources of both IRL3705Ns together, and then connect them to the negative (-) battery terminal.
Connect the drains of one IRF4905 and one IRL3705 together, then connect that to the positive motor lead.
Connect the drains of the other IRF4905 and IRL3705 together, then connect that to the negative motor lead.
That leaves only the gate pins of each transistor unconnected. Connect the gates to the pins on the main board as indicated.
Old 01-01-2004, 12:47 AM
hmmm...maybe i connected something wrong. Sorry about that.
update: Is working
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 01-11-2004, 12:34 PM
Declyn
If I was to wire the new FETs as described in the last schematic, could the servo and everything else on the original board opperate on just two AAA?? Leaving the other battery compartment for say a 9V wired to the FETs?
Old 01-11-2004, 02:06 PM
scatmanjohn01 scatmanjohn01 is offline
ok neuro..
so if i wire it like in your diagram, do the positive and negative wires from the batterys still have to connect to the 2 gold disks that have (3) and (2) next to them on the pcb?
same thing doing a direct connect to the motor wires.. do the motor negative and positive wires have to be connected to the golddisks with (6) and (7) next to them on the pcb still? 0r can the positive and negative motor wires just hookup directly to the fets? thanks
Old 01-11-2004, 03:04 PM
TypeZer0's Avatar
0reZepyT
according to neuro's latest diagram, the battery will connect to the pins on teh FETs (but don't remove the existing battery wires from the pcb....pcb still needs juice ) and the motor now attaches directly to the FETs
Old 01-11-2004, 03:56 PM
ok it still doesnt make an sense to me..
Old 01-11-2004, 04:13 PM
TypeZer0's Avatar
0reZepyT
just follow the diagram a few posts up. where he labels + or - battery, solder a wire at those pins and connect the other ends to the battery terminals. where he labels + or - motor, wire that up to the motor. wherever he labels IC6 Pin 4 or whatever, just solder a wire there then find where pin 4 of IC6 is on the pcb
Old 01-11-2004, 04:40 PM
neuro can you post a pic of the pcb with your mosfets added
Old 01-15-2004, 09:23 AM
yoohoo?
Are lipos and FETs worth it? Answer here Jazz32 XMODS Parts and Hop-Ups 24 10-29-2006 08:54 PM
Stock FETs max Amps? 4Runner XMODS 2 05-03-2005 10:53 PM
iWaver PRO FETs Revealed! aaron Mini-Z - Mini-ZRacer.com 0 12-17-2004 08:33 PM
Smoking Xmod!!! 4562 fets? chc XMODS 6 09-21-2004 01:42 PM
