09-11-2002, 08:02 PM
My Car Doesn't Work Any More
My 3.0 and 2.6 engine no longer seem to be working, the 3.0 is brand new, they both jump a little bit when I mess with them, then they die and don't do a thing. I miss them, the 3.0 can't be broken all ready
09-12-2002, 12:14 AM
Have you tried them in another car to make sure it's not the car itself?
09-12-2002, 12:22 AM
Come on Civic! Fess up! What have you been doing with your car?
You been playin around, having a peekaboo in and under the PCB? Hmmmm?
You can check these boards, there's PLENTY of advice on how to diagnose and fix your problem.
Here's a few things to try:
- Put FRESH batteries in your controller
- If you've messed around with the PCB, have another look and see if you didn't pinch any wires when you put it back together
- Look for broken, cut or pinched wires...Especially any going to the motor
- Lift the car and manually try turning the rear wheels. It should be pretty easy to turn, if there's a good bit of resistance...Then you need to check the gearing
Try some of those things and see how you do.
09-12-2002, 09:32 AM
well i know it is the engine cause i tested it in other cars, also this 3.0 is different from the other one i have, this one is shinnier and seems bigger, it also has a bit lighter color base to it than my other 3.0, i ordered them both from toyeast, so why is one different??
