Old 11-12-2002, 09:18 PM
JBit's Avatar
JBit JBit is offline
go Go GO, JBit Mifune!
3.0=Lucifer Rotor?
I just think it's funny that the motor has its own name. The Micro B 3.0 motor, or the "Red Motor," is named the Lucifer Rotor on the packaging. I think I'll pass and give this one to my friend, I can barely keep up with the 2.2 (I do spin-outs constantly with it!)What are the names of the other replacement motors?
The Mach w/DKS 3.4 Darkside Rotor.
Old 11-12-2002, 09:48 PM
henry's Avatar
henry henry is offline
13B REW
i got a 3.4 called "Darkside Rotor" .
Old 11-13-2002, 12:31 AM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
I have the blue capped motor rated at 10,000 RPMs called the "Stock Motor".
Old 11-13-2002, 04:07 AM
Zakkorn's Avatar
Zakkorn Zakkorn is offline
Life's a... Bits
Send a message via ICQ to Zakkorn
"Stock Motor"
WOW!
  • Nissan Gloria 2.6 + LightMod + 120mAH Cell -- Honda S2000 Silver 3.0 -- Nissan Fairlady Z 3.0 -- Toyota Supra Silver 3.0 -- Mach 5 3.8 -- Ultra Patrol 3.0 -- Ultra Cosmo 2.2 -- Auto Modellista 2.2 -- Bir Racer TRAX Green 2.6 -- DigiQ Subaru Impreza -- Ferrari Set -- LXX -- AudiTT SE ZipZaps -- Mazda RX-8 XMen ZipZaps
Old 11-14-2002, 09:44 PM
cowfish_29's Avatar
yellow fish forever!
some 3.8s are called "pink slip rotor"
also...get a tire set for your car with it's 3.0, so you can put harder tires up front and softer in back, no more spinning, just mellow turns and the 2.2 in the rear veiw mirror
Old 11-15-2002, 05:47 AM
RebellionInc's Avatar
RebellionInc RebellionInc is offline
Jetdi Knights
Hi, i'm sorry if this isn't the right thread but i need some advice/help. i just purchased a 3.0 motor and battery set from ebay. the battery works. the motor works but it kinda needs a push to get going. if not it will just studer along until a few inches then it will go. and not as fast as i expected a 3.0 to go. can anyone help me???
SPeEdiNG TiCkeTs SuCk
May ThE ForCe Be Wit Ya
Old 11-15-2002, 12:51 PM
JBit's Avatar
make sure that the gears are firmly meshed. if you think the one on your motor might be to blame, replace it with the gear from your old motor - that should do the trick. if the motor is misaligned, you can fit it snugly in place with half a matchstick (found that mod thru the tinyrc search function)
Old 11-15-2002, 01:07 PM
Jetdi Knights
the motor works but it takes of really slowly an gittery. should i send it back or can i fix it?
Old 11-15-2002, 05:27 PM
henry's Avatar
13B REW
rebel, my 3.0 dose the exact samething and i just dont use it no more. it seems slow 4 a 3.0 and i think it had happend 2 other unlucky people such as us. . just buy or return and get a diffrent motor.
Old 11-15-2002, 11:28 PM
cowfish_29's Avatar
if it stutters, then its most likely not the motor. The reason lower speed motors work, but 3.0s dont is because lower motors have more torque to push gears that are binding. At a standstill, driving a 3.0 is like starting off the line in 4th gear...lots of strain, not much torque, and takes a long time to hit top speed. Your gears need to be loose...try moving your motor positon with folded paper or something...just try to get your transmission to the point where if you are on a smooth surface, your car will roll around just by pushing it, so it freewheels kind of. This might help.
Old 11-15-2002, 11:40 PM
henry's Avatar
13B REW
cowfish, its the motor that is brokin on minez, cuz i took all the gears out and tried the motor alone, and it studders and stop, till u toch it.
Old 11-16-2002, 06:04 AM
Jetdi Knights
THANKS COW FISH... i'll do that as soon as i wake up in the morning!!!!!! hope it works
Old 11-16-2002, 06:05 AM
Jetdi Knights
COWFISH.... does thatr mean that a 3.8 wont have any acceleration?
Old 11-18-2002, 12:22 AM
Blue Bit's Avatar
Blue Bit Blue Bit is offline
Toy Collector
Hi ... Is th 3.0 motor sold here at TinyRC an orig Tomy(Bit Racer) ?
NSX-R , FairladyZ33, Auto Modellista, AE86 Trueno,
Calsonic R34, R34(WHT), Evo VII(YLW)
Old 11-20-2002, 06:03 PM
JBit's Avatar
it's sold as a Bit Racer part, not Char-G.
I installed mine today (decided to keep it since my friend will soon have a 2.6 booster set - got to keep competitive!) and this this is wicked! i had to totally change my driving technique, like stabbing the turn and keeping the accelerator on in order to avoid spinouts - this thing can do a perfect slow drift in a big circle, awesome! i know it's not the steering that is sluggish, because the second i lay off the gas it does a spinout unless i counterturn, lol.
that was all on a hardwood floor. on the kitchen tile it was amazing - i had better handling (i guess ceramic=better driving surface) but due to the bumpiness in between the tiles my Mach flipped over for the first time, even did a few 2-wheel side wheelies lol. this thing has serous top speed, but the torque is a bit lacking.
i think overall i will keep this 3.0 under wraps and use the 2.2 when racing my friend's AE86 (1.0 and axle set) but when his booster comes, watch out!
Subaru WRC Body & Rotor pics pigeonfarmboy Mini-Z - Mini-ZRacer.com 7 11-09-2003 07:26 PM
FS: BCG fairlady z booster w/3.4 rotor takumi_drifto For Sale/Trade 6 09-10-2003 05:27 PM
DKS 2.8 Monkey Rotor aero ZipZaps 8 02-09-2003 06:01 PM
3.8 motor or DKS Darkside Rotor? MicRoMaN Bit Char-G / MicroSizers 1 12-08-2002 01:42 AM
