Old 10-30-2002, 08:11 AM
DJ_Mo DJ_Mo is offline
Send a message via AIM to DJ_Mo Send a message via Yahoo to DJ_Mo
Unhappy Help ! New Bit Char-G doesn't work :(
I finally got in my Auto Modelista kit in a few days ago. Opened up the package, charged the car..and then 45 seconds later, nothing happens. The car just sits there.
I got suspicious, and then charged the car on my Hobbico controller. And then the car works like a charm with the Tomy controller.
So looks like my charger is busted on the Tomy controller (which is suprising, as the light stays on 45 seconds and goes off..which looks like it is chargin..but the car doesn't have a single bit of actual charge in it).
Can anyone come up with a good fix for me on this ? Something simple I hope .
Old 10-30-2002, 08:13 AM
MICROMAZDA MICROMAZDA is offline
Send a message via Yahoo to MICROMAZDA
Maybe you have bad bats in the controller?
Old 10-30-2002, 08:31 AM
MicroMazda...just put in a new set of batteries on the TomyController...still no luck
Old 10-30-2002, 09:25 AM
Check the contacts. Are they bend or out of shape? If so, bend them back straight. Only other thing I can say is bust the controller open, see if the wire is making full contac??
Old 10-30-2002, 05:30 PM
cowfish_29's Avatar
yellow fish forever!
i think that if the light is operating normally but there is no power being sent to the battery, then it is something internal with the controller, and therefore probably hard to fix. You might wanna open it up and look for anything suspicious (loose, soldered bad, in the wrong place ect)
if you got it off of ebay, i would not reccomend sending the controller back for another one, cuz when i did that 2 months ago, and my car is STILL not here...stupid ebay sellers dawdling.
Old 10-31-2002, 03:24 PM
cowfish29
Yeah I did get it from eBay. The car works, but I have to just carry two controllers around with me now..LOL.
Is is safe to open the controller ? I am not going to get any parts fly back at me ..am I ? :[
-Mo
Old 10-31-2002, 03:29 PM
ph4nt0mtun3r ph4nt0mtun3r is offline
Send a message via AIM to ph4nt0mtun3r
you shouldn't get any parts clying out at you, I opened mine up just to look at the cripple cap and nothing jumped out, just be careful with all the little wires, and don't lose the small screws.
silver s2k to start me off... chopped top
and dual exhuast
"come on widdit!"
Old 10-31-2002, 03:43 PM
Napalm_Guru's Avatar
Napalm_Guru Napalm_Guru is offline
Wanna Drag??
I have a similar problem with my Auto modeilista but the trick is to hold down your car the the prongs on the charger then it charges. Tell us if this works.
-Jed Babbin
Old 10-31-2002, 03:51 PM
DeeChan DeeChan is offline
it should work since when you put the car down on the prongs, it completes the circuit and lights up the led...hmmm
I have the whole booster set for a ZZ but it doesn't have the stabalizers for sale. Email me for more info.
Antenna from RS-4$
Ripping off some useless controller plastic- negative 2$
getting 15'+ of range-priceless
Old 10-31-2002, 04:14 PM
Wanna Drag??
It could also be that your batterys in your controler are near dead try swaping batteries with your other controller and see. When I got my first bit I ran the batteries down in 2 days! and thought my bit died.
-Jed Babbin
Old 11-01-2002, 09:17 AM
AceQ AceQ is offline
I just got found the EXACT same problem on a Huale Knock off. We ended up diagnosing it to a bad resistor. Take a look at all of the resistors. When we replaced the bad resistor it worked like a charm.
I won't be able to get pictures up until Wednesday of next week if you need them.
-AceQ-
Old 11-01-2002, 02:18 PM
JaMeZzZ122 JaMeZzZ122 is offline
Send a message via AIM to JaMeZzZ122
i ssay contact tomy or hobbico...they'll help u out
Town for Bit Char G Seb123 Bit Char-G / MicroSizers 2 03-30-2003 11:22 AM
digiq R or MICRO rs4 or bit char g? sengming Bit Char-G / MicroSizers 3 02-10-2003 08:28 AM
UK bit char g life ......... boring Bit Char Bloke Bit Char-G / MicroSizers 10 11-10-2002 08:10 PM
Are Bit Char G parts compatible with Micro mites?? SPEED Bit Char-G / MicroSizers 2 08-20-2002 05:31 PM
