Old 02-24-2004, 09:00 PM
spinitsidewayz!'s Avatar
boro dori style RC
dampers?
anyone know what to use for damper oil? or any better dampers then thse xmod ones... are mini z suspension components any better?
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-24-2004, 09:38 PM
boro dori style RC
thanks for the info. im thinking of getting a mini z. quality of the xmods just isnt cutting it for me.. well on my xmod, what could i use to stiffen the damper?
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-24-2004, 09:39 PM
Sky_Liner's Avatar
Sky_Liner Sky_Liner is offline
Send a message via AIM to Sky_Liner
Damper oil is for oil shocks which are on most 1/10 scale models
I found an bottle in a box of r/c stuff and I then found my dads old Tamiya Hornet, I saw the book saying the instructions on oil shocks. but I dont know bout the mini-z at all.
just the tamiya hornet and xmods
Peace
Old 02-24-2004, 10:10 PM
boro dori style RC
ok maybe i should make my question clearer lol. what could i stick in the xmod shock/damper/strut thingy lol w/e it does... it doesnt really work as a damper(doesnt do anything)... something kinda sticky or thick to make it compress like a damper...?
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-24-2004, 10:24 PM
jco jco is offline
tamiya has a product called Tamiya Sliding Damper grease . package contains three small tubs, hard(purple), med.(blue) soft (green) avail at your LHS
l
the stuff looks like colored silicone grease with the feel of say peanut butter, weird stuff , works wonders.
works great with xmod friction dampers (shocks)
put a tiny dab on end put together and bam! takes the bounce out of them. have used this stuff on larger scale friction dampers
my xmods - med. springs ,soft (blue) grease
hope this helps
btw i wouldnt use "normal" grease or a silicone type...it tends to break down quick
never jump in the water...use a ladder
Old 02-25-2004, 07:07 AM
RC 2NR RC 2NR is offline
TinyRC XModder
Are you insane...how much heat and friction do you think the dampers get put under?
Grease or silicone would work fine.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-25-2004, 08:53 AM
jco jco is offline
quote - "Are you insane...how much heat and friction do you think the dampers get put under? "
if u use typical grease or silicone base the word "breakdown" means that even in these little dampers(or any rc friction damper) it will start to move out of the dampers and make no difference other than a real mess, with the tamiya grease, it stays where u put it
hmmmm lets replace "breakdown" with ...lets see, the word ..."migrate"? hehehe
and no, im not insane just a bit crazy
Old 02-25-2004, 07:52 PM
boro dori style RC
haha alright thanks jco. ill look into getting some of this stuff
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-26-2004, 08:11 PM
dietryin's Avatar
dietryin dietryin is offline
title? i dont have one!
Send a message via AIM to dietryin
and for the record.. the little cars, little shocks, low GC make for a lot of bouncing around or slight movement.. but causing a lot of friction.. its suprising actully
just say no to big sigs
heh.. stolen from viperdout^
