  #76
Old 12-18-2003, 07:54 AM
neurokinetik's Avatar
Originally posted by LithiumXmod
I did the same Fet upgraded as neurokinetik.
Cool, glad to see somebody else has given it a try. How's it working for you?
Evomod
LithiumXmod,
Can you shed some detail on how to wire up the FET upgrade?
Old 12-18-2003, 04:14 PM
LithiumXmod LithiumXmod is offline
The FET upgrade is working great. Then again i just have a stage one motor with 8 tooth pinion. I have a Pnracing S03 on order, im sure is going to push the fet's. Im still tryin to figure out a way to add heat sinks to keep the fet's cool. SIde mount, maybe? I used CAT5 cable as well, standard kind. As for wiring, look at neurokinetik picture diagram of the fet's. Its self explaintory.
LithiumXmod
Mods:
4 Cell CR2's Photo Lithium Batteries
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Suspension - Front: S Rear: H
Steering - 1.5 degree Tie Bar
Coming soon:
Ball Bearings
Old 12-18-2003, 09:52 PM
Evomod
How is it wired back to the car?
Old 12-19-2003, 03:19 PM
Evomod you need to remove the whole PCB from the xmod and unsolder the fet's on the underside of the FCB. I drill a small hole on the side of the xmod, to run the wires from the underside of the pcb to the top. I'm sure there are other ways, but that's how i did it.
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-19-2003, 03:39 PM
If you are really creative with how you route the wires, it isn't even necessary to cut the chassis. Running everything through a hole could provide a much-needed way of providing strain relief, though.
Old 12-19-2003, 03:55 PM
neurokinetik what do you think of pnracing s03 motor?
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-19-2003, 05:41 PM
Haven't tried one, but it's supposed to be decent, for a 130 motor. If it sucks, at least you have a nice BB can with Neos to stuff a new armature in...
Old 12-19-2003, 05:44 PM
Yea, that's true. What kind of motor do you reconmend neurokinetik to take advantage of the new fet's? (stayin to the topic)
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-19-2003, 05:52 PM
Actually, the S03 is probably a good choice, or else a 35 turn motor that uses 28 Ga wire. That pulls some juice.
Old 12-19-2003, 05:57 PM
What motor are you using neurokinetik?
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-19-2003, 09:24 PM
FeRReT_of_WaR FeRReT_of_WaR is offline
when you guys are done with this modding. can you post a step by step guide to fet upgrading. i kinda understand. but what does it mean by turns in the motor. i have taken a motor apart and seen the inside. and there were three arms how does the wire go around? is it like 15 or something turns for a arm and you move the wire on over to another arm?
Old 12-19-2003, 09:55 PM
Well, I've got a nice little collection of experimental hybrids, but mostly I'm running 180 motors now.
Old 12-20-2003, 01:55 AM
neurokinetik, do you know where i can buy a replacement pinion gear?
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-20-2003, 11:39 AM
Yeah, you can get a set of four for $12.99 from Radio Shack. They'll even throw in four motors for free...
Other than that, I have been unable to locate a really good replacement.
Are lipos and FETs worth it? Answer here Jazz32 XMODS Parts and Hop-Ups 24 10-29-2006 08:54 PM
Stock FETs max Amps? 4Runner XMODS 2 05-03-2005 10:53 PM
iWaver PRO FETs Revealed! aaron Mini-Z - Mini-ZRacer.com 0 12-17-2004 08:33 PM
Smoking Xmod!!! 4562 fets? chc XMODS 6 09-21-2004 01:42 PM
