Old 08-28-2002, 07:26 PM
_NiTrOuS_'s Avatar
_NiTrOuS_ _NiTrOuS_ is offline
My Bit
I finally got my Bit Char-g WRX! But I also got a gear set. if i use one of the gears i have to use a whole new axle. But the only problem is that the normal axle is gold. It looks retarted with one gold and one chrome like axle. is there any way to just change the gear and save the axle? So I can just somehow use the old axle and use a new gear ratio?
Old 08-28-2002, 07:28 PM
me2cyclops me2cyclops is offline
psYkO
It is possible
check out qfm's site and look at the Lowering mod to get the details on swaping wheels on the rear axel
Old 08-28-2002, 08:54 PM
_NiTrOuS_'s Avatar
ive been looking at that for a while. its just i need to get a drill or something as small. I guess ill just use the full size wheel mod and that'll solve it.
Old 08-28-2002, 09:26 PM
_NiTrOuS_'s Avatar
or wait a minute, cant i just use a different gear that connects the motor and the axle instead of using the stock orange one? All of the gears that connect the motor and the axle are different sizes. But the only problem is that it won't be as effective. Also, if I do that, is it bad for the bit?
Old 08-29-2002, 10:38 AM
cowfish_29's Avatar
yellow fish forever!
yeah...thats a dillemma...I have the same exact setup as you. I have the white wrx and the axle set. I just took my little brother's zexel (black) axle and used it for the light blue gear ratio and that looks...OK... but if you want it to be all the same you could just pull the pins out and change your front wheels. Ive found that trying to change gears around to a non-factory type way makes the cars bind and not run as well, even if it is the correct gear ratios.
Old 09-01-2002, 12:32 AM
_NiTrOuS_'s Avatar
well, i decided to just do a fullsize wheelset mod. how do you seperate the rim, axle and the gear? or just seperate the rims from the gear and the axle? Do you have to break it off? Or cut it? I don't wanna break anything unless absolutely nessesary. I only have one bit so i cant use any other front wheels...
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
Bit tires vs Microsizers tires Dys70pia Bit Char-G Parts and Hop-Ups 3 12-28-2002 04:34 AM
Entire Bit collection for Sale (Customized Bits) bitfreak Bit Char-G / MicroSizers 10 09-13-2002 08:28 PM
