Old 02-14-2003, 10:40 AM
Zephyranthes's Avatar
Blitzer Sonic
My rear tab broke
One half of my rear tab snapped off. The one where the heat sink lock goes into. How do you fix it?
Old 02-14-2003, 10:55 AM
savage sound's Avatar
savage sound savage sound is offline
Get a new chassis.
jack of all trades master of nothing!
Old 02-14-2003, 11:26 AM
~SnakeBitRacer~
Thats a relly good suggestion (sarcasm) That happened to me too. If you can't clip the motor down then just tape the heat sink
Old 02-14-2003, 11:38 AM
PWalk's Avatar
PWalk PWalk is offline
Where's the Beer?
Send a message via AIM to PWalk
Use scotch tape to tape down the heat sink,
BUT make sure you trim it down or else the body won't sit on the chassis correctly.
Good Luck
I'm taking the Bit's offroad!
Old 02-14-2003, 11:51 AM
btlmr's Avatar
btlmr btlmr is offline
TinyRC Chief
Send a message via AIM to btlmr
CA Glue will fix it. Its like super glue bet a bit thicker and not as brittle.
My current bit I actually cut off the front and rear tabs and re-glued them back on lower down with CA glue. Allow to dry and tidy up with a file and its has strong as before.
My first bit I lowered the body by cutting slots in a different place and trying to repair the old slots and paint it. It looked poo, because I am no good at painting and body repairs.
butler
_______________________
Size clearly isn't everything...
Old 02-14-2003, 12:22 PM
Blitzer Sonic
What does CA glue stand for. I used some epoxy and its kind of gooey. It holds pretty well, but not as strong. You can see the tab bend a little bit when the heat sink is on.
Old 02-14-2003, 12:26 PM
btlmr's Avatar
TinyRC Chief
I can't remember its a long chemical name.
butler
Old 02-14-2003, 12:27 PM
btlmr's Avatar
TinyRC Chief
After looking on google:
Cyanoacrilate (super glue, AKA CA)
Apparently its used more in 1/10th RC for sticking tyres to rims.
butler
Old 02-14-2003, 05:48 PM
Blitzer Sonic
If it is stronger than super glue, where can you get it?
Old 02-14-2003, 07:57 PM
Hatchet_Dan's Avatar
Hatchet_Dan Hatchet_Dan is offline
Juggalo Bit Drag Racer
Send a message via AIM to Hatchet_Dan
your LHS or if your lucky like me and live about 2 blocks from a r/c race track g up there and ask some one if you can use theres
Old 02-14-2003, 08:29 PM
denden's Avatar
denden denden is offline
Mini Rc Enthusiast
While doing some of my customs , I found it necessary to remove
that tab . I then glued the motor in place . It works fine , but
I suggest you glue a motor that you don't plan to remove again.
Old 02-14-2003, 09:44 PM
AudiTF's Avatar
AudiTF AudiTF is offline
Evo VII
Send a message via AIM to AudiTF
Go
If it's a microsizer e-mail them and they will send you a new chassy
________
Chrysler lh engine
Old 02-14-2003, 11:10 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
if u mail me a SESA ill put a clone chassis in it.. what freq do you use? i may even be able to put the pcb and steering coil sin there assumign you have a freq that i have.
Old 02-15-2003, 12:27 AM
Blitzer Sonic
It's a 49mhz MicroSizer. I emailed Hobbico, hopefully they will answer.
Old 02-15-2003, 02:09 AM
PseduoRooter's Avatar
PseduoRooter PseduoRooter is offline
I hate suits!
Quest for Madness sells bare chassis for $5, you might have to pick up a matching controller too, which is also $5. I am suffering from the same problem. I am tired of regluing the tab. I spend more time gluing than running it seems.
Rear locking tab? Burnout XMODS 1 04-04-2005 12:16 PM
Broken rear tab dje7447 Bit Char-G / MicroSizers 2 01-07-2004 10:19 PM
Rear Wheel just broke off EMX XMODS Parts and Hop-Ups 6 11-28-2003 10:10 PM
Tuning Basics sperry XMODS Parts and Hop-Ups 12 11-19-2003 01:56 AM
I broke a rear wheel connecting rod the other day.. Rotary Freak XMODS 0 11-11-2003 08:49 PM
