Old 01-02-2003, 11:55 PM
shocon2k
Full Size Wheelset....screw that!
I tried doing a fullsize wheelset with a spare set of steering knuckles I have and the extra stock axle, and I did it, and it looked great, however my car could only turn left. I have no idea why. It would turn KINDA left if I let go of the gas and held the button, but not while driving. So, I guess its back to those ugly ass small wheels in front. :-/
Old 01-03-2003, 12:18 AM
Riven Riven is offline
<-Buying Electromag Coils
Did u make sure it wasnt rubbing tyhe chasis or body?> i have to grind mine down a little bit. If u turn the wheel by hand does it wobble? my friend drilled his hole a little crooked and made his unable to turn at all hardly however it would some still
Old 01-03-2003, 03:23 AM
Shypo's Avatar
Shypo Shypo is offline
Regulator
most shells have problems with the rim "biting" the shell becos of the size up front
go fast, be free, with low CC
Old 01-03-2003, 08:21 AM
Odin_Knight's Avatar
Odin_Knight Odin_Knight is offline
Send a message via ICQ to Odin_Knight
my advice is to try the car without the body 1st. if it works nice then you'll know where's the problem. if don't just try to check if the changed rims are scratching the chassis or if the returning spring is well positioned (a say that because last time i messed with the rims my spring jumped out and the car was not able to turn to one side).
Old 01-03-2003, 09:12 AM
bill's Avatar
bill bill is offline
I are smart....
If it does turn without the body, you will have to sand down the inside of the shell where the tire hits it. I had to do that on my skyline.
Old 01-03-2003, 02:53 PM
shanly
i think you should get ahold of some zip zap rims, they look cool and lose that ''stock'' look to the car
Old 01-04-2003, 12:28 AM
shocon2k
Well it behaved the same way with the body on or off, so I put back the stock wheels. Then I said just for the heck of it to put em back on and viola, they worked great. So now I have fullsize wheels...and they look bangin.
Old 01-05-2003, 07:52 PM
shanly
actually, your car is nothing compared to mine
size of screw for gpm steering knuckles? Clint XMODS Parts and Hop-Ups 4 07-02-2005 04:40 AM
looking for full size wheel mod BCG/MS ucfdan Bit Char-G Parts and Hop-Ups 3 09-02-2003 07:54 PM
looking for info full size wheel mod for BCG/MS ucfdan Bit Char-G / MicroSizers 5 07-07-2003 09:17 AM
Using a full size r/c controller? Sniper596 Bit Char-G / MicroSizers 6 11-02-2002 12:09 PM
full size wheel mod.. Need4Speed210 Bit Char-G Mods and Projects 2 10-20-2002 12:28 PM
