Old 08-07-2002, 06:06 PM
korosu korosu is offline
Question incline grades
Hello all, i'm a newbie here and before I get my first bit I'm already thinking about building a track. Anyway, my question is what is the steepest incline that the bits can climb? I know motors and gear ratios will affect the climbing ability.
Any help will be greatly appreciated.
Old 08-07-2002, 10:23 PM
Zagatto
There are a lot of variables to your question.
Gear ratios
tire compound
incline surface
acceleration distance before incline
length of incline.
From a standing start, my bit with a 2.2 motor, orange gears, and the standard black tires can handle an approximately 30 degree incline on vinyl and have managed over 45 degrees with a running start (can we say jumps are fun?).
Old 08-07-2002, 10:36 PM
yeah, i figured this would be a difficult question. but the 30 degree incline from a standing start is a good reference point. basically, i'm thinking of a track with a bridge or two and just need to know what angle i should stick with to make sure the bits can go up.
thanks a lot!
Old 08-07-2002, 11:53 PM
cowfish_29's Avatar
yellow fish forever!
a loooonnngg time ago in a land far far away, cowfish once had a track. It was a figure eight with a bridge.
This bridge was tricky business because i did not have that much space, only about 3 ft. It needs to be mellow enough to roll over (barely nothing) and has to fit a bit underneath. Remember antennas. If you can get the underside of the bridge smooth, then you can make it so the antennas rub on it.
Most of all, test it before you build it to completion.
(Message from TheFanMan): a good way to scale and measure the bridge would be to make it about a 1/2 inch taller than a bit. This way you have enough clearence for a bit and you can still get enough power to roll over it
Different Grades of 3.0 motors burningtea Bit Char-G / MicroSizers 2 09-20-2002 02:50 PM
