Old 10-25-2002, 02:49 AM
ZenFlea ZenFlea is offline
Question ABC DTM newbie-- help unleash the beast
Hey all,
Breaking the seal with post #0001. I'll be receiving a used rolling DTM SP chassis next week and I was hoping to get some advice from you all about setup. This is my first foray into RC in over 10 years so I'm a bit anxious. Does anyone use the ABC CRP (esc, servo, rx) module on their SP? If so what do you think of it and are there any problems with body fitment or motor handling ability (can it take a 180)? Recommended esc, rx's that are comparable pricewise? I plan on running on asphalt mostly. Oh and finally, does anyone have the DTM SP manual they'd be willing to scan or part with to help a brotha out?
Thanks for the help,
Z
Old 10-25-2002, 08:32 AM
preliminary setup
Alright after a little research this is what my SP might look like pending input from you guys:
ESC: Futaba mc230cr (would Novak Spy be better? need something with reverse)
servo: hitec hs-81mg
RX: hitec hfs-03mm (anything smaller? differences between AM and FM?)
transmitter: Futaba Magnum Sport or Junior? (is the difference noticeable with such a small car?)
motor: orion elite stock or gpm high speed? (would i have to solder caps on myself?)
suspension: kyosho mini-z springs up front (yellow), no damper in rear, full bearing set
battery: 600mah abc nimh pack (are there higher mah cells in this size?)
bodies: Tamiya 1/24 scale model Denso Sard Supra http://www2.towerhobbies.com/cgi-bin...1&I=LXGT47&P=W and Porsche 911GT http://www2.towerhobbies.com/cgi-bin...1&I=LXGT55&P=W
Also what's a good, cheap variable rate charger? As you can see I'm flying blind here. Any help MUCH appreciated.
Thanks,
Z
Old 10-25-2002, 06:25 PM
dtmracer dtmracer is offline
hi, i used to use the tamiya crp unit on mine. i took off the plastic case and heat shrinked it. yes this can handle the 180 motors. i like the crp unit mainly beacause its soooooooo small and light. the only downside is the somewhat big servo that comes with it. i wish i could change servos but cant. i went with a orion coreless mod motor and switched electronics though. i use the duratraxx intellipeak charger, runs about 55 bucks i think. there is another similar to it, called the brain. i forgot who made it but it is good also and i think it is 40 bucks.
Old 10-25-2002, 06:35 PM
gertman's Avatar
gertman gertman is offline
tamiya crp
Sorry I am unfarmiliar with this? Do you by chance meen the ABC crp unit?
-Engineering Manager
Old 10-25-2002, 06:42 PM
gertman's Avatar
ZenFlea,
I had a lot of trouble with my ABC crp unit so I don't use it anymore. I would suggest they SPY over any other ESC. For a receiver, it depends on whether you want AM or FM. FM generally gives you better range and less glitching. Unfortunately, no one yet makes a 75mhz FM receiver. By the way, the ABC CRP unit is available in FM 27mhz. Mini-Z and Epoch's are on AM 27mhz. Just so you know, AM and FM are NOT compatible.
Old 10-25-2002, 09:03 PM
FM receiver
Found this on towerhobbies website:http://www2.towerhobbies.com/cgi-bin...1&I=LXCBC7&P=0 Would this work with a Futaba Magnum Jr. 2peka 75mhz? Also anyone have the kit manual?
Thanks again,
Z
Old 10-25-2002, 09:05 PM
yeah, i bought the crp unit made by tamiya. its 75 mhz. it is the one with the rx and esc in one little black case. i the abc one is different.
Old 10-25-2002, 11:24 PM
gertman's Avatar
ZenFlea,
That receiver you linked to looks monsterous!!! I think it's WAY too big.
Don't get me wrong, it would fit BUT I would suggest a smaller lighter one.
The smallest good quality FM 75mhz receiver is Novak's XXL
IF you want an AM 27mhz receiver they are smaller. I would suggest the one from the Mini-X or the Hitech Shredder.
IS your Futaba remote FM or AM?
Old 10-25-2002, 11:51 PM
The Hitec receiver is actually only slightly larger and heavier than the xxl but I guess Novak is the only way to go. I'm bidding on a FM magnum jr on ebay hence the need for a good fm receiver.
So revised and pricier setup:
ESC: Novak Spy $56
RX: Novak XXL FM 75mhz $59
Transmitter: Magnum Jr. FM ---bidding
servo: Hitec hs-81mg $22
bearing set: $25
motor: GPM High Speed
kyosho yellow springs
600mah nimh
How does this look? Overall I'm spending quite a bit more than I originally planned. Venturing in on micro rs4 territory. I won't be able to invest in any other car for awhile. Will this whip put together make me forget all about the micro? I don't mind the outlay as long as the performance doesn't have me wishing for more soon after.
THNKS
Z
Old 10-26-2002, 12:17 AM
gertman's Avatar
Yeah your probably right, the picture they had of the receiver was of a different model.
Anyway I would say YES you will be a ton faster BUT let me warn you, an SP is alot harder to drive than a Micro on some tracks. You know the SP is rear wheel drive, right?
So what have you decided about a charger?
Old 10-26-2002, 02:07 AM
irc irc is offline
IM running the Mini X electronics in my SP with very good luck.Hitec does make a Micro FM receiver that is slightly smaller than the Novak. That and an ES01 would work and save you a bit of $. The HS 81 MG is a good Hitec micro servo. I think this would be a good set up for the $. You could also use an Mtroniks ESC in place of the ES01 but it is larger. You should expect a very fast car with the 180 motor and a good battery!!!
" THINK FAST "
Old 10-26-2002, 12:50 PM
gertman's Avatar
the ES01 won't work with a GPM 180 motor!!
Old 10-26-2002, 01:45 PM
Thanks for all the suggestions guys. I was worried there wouldn't be much support for the ABC's. Yes I know the SP is RWD. The drivability on technical tracks isn't quite as important as runtime (the X4 has a much smaller battery) and speed for me. There aren't many tracks around me much less any other 1/24 scale cars to legitimately race against so this car will probably see most action on the large newly paved parking lot near campus. I've decided if I'm doing this I might as well do it right and not skimp on electronics. The thought of having electronics that can handle moving up to larger motors when I eventually get an rs4 makes sense. Well I guess I'll have time to paint and detail those two Tamiya models while I'm slowly saving up for every component.
THNKS,
Z
Old 10-26-2002, 11:55 PM
irc irc is offline
Hey Gert,
I did not know he was running a GPM 180. I have an ES)1 in my RS4 with the stock 180 with no problems
" THINK FAST "
Old 10-30-2002, 02:18 PM
Mondo Mondo is offline
As an owner of a few Micro RS4s and Mini-Z's, I know what's out there regarding small scale electronics.
I am still tempted to debble in an ABC, but the Micro RS4s are taking up too much attention right now (Indoor racing season)
The electronics of choice have to be the Novak SPY and XXL.
The Quantum Pro Micro is also an awesome small scale ESC.
As these can handle 7 cells and a BB300 motor on a Micro RS4, they should be ideal for an ABC DTM
Just my 2c worth
Second place is first loser...
How to make your DTM RR run like the ABC DTM MicroRCEngineering Dynamite Rocket Racer Parts and Hop-Ups 2 01-03-2003 03:00 PM
ABC DTM X-4, details gertman ABC DTM X4 7 10-21-2002 02:09 AM
abc dtm products was ist los? TinyRC.com Shop Support 1 10-19-2002 10:50 PM
Abc Dtm Oman ABC DTM SP 4 08-25-2002 03:09 AM
