Old 10-31-2002, 05:19 PM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
Lightbulb Clone Motor Mod
Since I was reading alot of post about how fast clone motors were and I torn into my clone before I had a chance to find out.
I decided to mod it to work in my MS and my zip.
The diffrence in motors is how they connect to the power (clone motors are hard wired). I first striped the insulation totally off the ground wire and used my soldering iron to melt a small portion of rear motor plastic to expose a small section of the motor can. Kinda like a slot. Then layed the strands of the ground wire into the slot and droped a small bead of solder into the slot, also soldered a small part of the excess strands of the ground wire to the motor can itself (this was to prevent the solder from breaking free from the slot during handling). Then with a scrap of Plastic (from another project) I melted a bit to the tip of the soldering iron and placed it into the slot to cover the solder. Once this was done I clipped the remaining strands of the ground wire from the can leaving the wires soldered to the motor can intact. Next I layed the positive (red) wire over the rear of the motor and cut it so the wire went all the way across the rear of the motor. Look at a bit or zip motor and the positive wire and position should be similar in appearanceto those motors contacts. Then remove a little of the insulation from the positive wire and just tin the wire (DO NOT SOLDER TO THE MOTOR) and there it is a removable bit motor. This was a first attempt was a little crude only because I wanted to see if it could be done. So when I get another clone I will refine my methods and post a cleaner better way of doing it.
In the meantime, If any one else attempts this please post YOUR methods and results. Oh, on a side note the clones seem to be 2.2's with more advanced timing. This would explain some of the reason they are so fast. (Those who run of have run bigger electric R/C cars will know what I'm talking about.
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
Clone Reviews! Kenkudaki Bit Char-G / MicroSizers 32 03-06-2006 04:53 PM
motorwroks / other clone fused together! Impreza WR reX Bit Char-G Mods and Projects 0 02-22-2003 12:57 AM
clone ctlr works on ZZ but ZZ cntlr doesn't work on clone? ejaf ZipZaps 2 12-11-2002 04:05 PM
More Clone BS BillyBonz Bit Char-G / MicroSizers 2 08-30-2002 03:28 PM
Tomy vs. Clone BillyBonz Bit Char-G / MicroSizers 2 08-26-2002 04:54 PM
