Old 03-21-2007, 11:28 AM
rody rody is offline
Cars transmitter
Has anyone tried using the transmitter/charger for the Cars zips to charge an earlier generation zip? I tried holding an earlier zip on the charger last night, and the light went red, then green, but when I tried to run the car, it wouldn't go. I checked the voltage going out from the two contacts, and the Cars tx had twice the voltage (makes sense, since it uses four batteries vs. two).
I'd like to try and rig a charging unit on the Cars tx, because it feels better, and has a longer range. Can anyone help? Thanks.
Old 04-08-2007, 08:49 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Take the charging base out of the one that matches the car and swap it for the charging block in the controller you want to use. It's fairly straight forward once you take the two TXs apart. Just swap one block for the other.
Great..more micro cars to collect (Speedez) Rotary Freak Miscellaneous Discussion 6 02-15-2004 08:17 PM
After market bodies Roadrunner Bit Char-G / MicroSizers 58 01-17-2003 12:53 AM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
