Old 12-30-2003, 06:46 PM
civic freak's Avatar
civic freak civic freak is offline
Tiny RC Guru
Question pipe mounting help
ok i found this sweet pipe that i want to mount but its metal and i dont want to glue it in case i have to return the car or chrome it, oh yeah its a big ricer pipe so it drags the ground is there anyway i can fix that? thanx oh yeah BC if i send you my car along with $15 could you paint it for me? ill also pay postage.
Old 12-30-2003, 07:32 PM
Joey's Avatar
Joey Joey is offline
I'd need more exact information before I could lay out an exact plan for that, but I would suggest that you mount it by screw,if that's at all possible - I'm new to the structures of these things, I'm just assuming that there's something you can drill into.
On the subject of dragging: I came across a similar situation with my 1:18th C5 Corvette (rest in peace). I had an actual muffler attached to the pipe, so this wasn't really an option for me, but if you cut the ends at equal (but inverse) angles, then you could point the pipe upward past the body and cut some ground clearance at the same time. Two birds with one stone, I would say, since I like that mounting style.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 12-30-2003, 10:09 PM
Tiny RC Guru
huh???????
2 questions, what kind of exact information and can you explain that in laymans terms im only in 7th grade. if this is what you need it is an Acura Rsx with no body kit or anything else its a completly stock body
Old 12-30-2003, 10:46 PM
Joey's Avatar
Really what I'd need is the size of the pipe and where you wanted to put it, but that's not all taht important.
Basically, you'd hold the pipe at an angle and Dremel off the bottom part of it straight. That way, the part that would be scraping the ground before is just flat (not realistic but no one's going to be looking at it from the bottom).
Then, in order to keep it from looking like a collection pipe (and more realistic, since real cars would ruin their mufflers by not doing this) cut part of the top off, so that it's flat in relation to the rear bumper.
See if any of this helps. I'm on AIM at Maranello720R if you want to talk more directly.
Mazda Savanna RX-7
Old 12-31-2003, 12:51 AM
micro kid's Avatar
Do you getto dremel?
off topic
(off topic) hey civic freak im in 7th grade too and i have mounted a 68 L88 Corvette body (waiting on cash for ****ing velcro) you can do more than you think you can.
Problem mounting on tires and hubcaps blackbear ZipZaps SE 8 05-06-2006 04:27 AM
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 06:13 PM
How are you mounting your aftermarket bodies? sporttracguy XMODS 0 10-16-2004 01:08 AM
PVC pipe Tires scatmanjohn01 XMODS Mods and Projects 4 01-25-2004 07:40 PM
Custom body mounting tips micro kid XMODS Mods and Projects 0 12-31-2003 01:43 AM
