Old 11-22-2003, 11:49 PM
SpeedDemon SpeedDemon is offline
Microsizer Questions
2 questions:1. I hear people saying they have 20' range with their MS, mine has like 6 ft if that. Whats wrong and how can i make it better. 2. I hear people saying they can do wheelies with the Turbo Blaster. How do you do that?
thanx in advance
MicroSizer: Perfection 4.2 Pro
2nd Microsizer:
Old 11-23-2003, 12:48 AM
Rotary Freak's Avatar
Rotary Freak Rotary Freak is offline
Send a message via AIM to Rotary Freak
My range isin't all that hot either, but I just deal with it, if you wanna get technical I believe you have to remove the crip cap..or..something fancy like that. As for wheelies, yep. You can do those with a Clone if you've got enough power. A stock Shen Qi Wei can do wheelies like mad under the right conditions, if your surface is rather grippy, you can accelerate fowards, then "brake" backwards and your front end should raise up quite a bit. Its quite a spectacle. And yes, it works quite well with Turbo Boost, but only it works the same way. If someones got a Turbo Bit that has so much torque that it raises their front end as it launches, I'd like to see it.
I wish my Land Rover was a rotary
Old 11-23-2003, 08:59 PM
viperkilla's Avatar
Re: Microsizer Questions
thanx in advance
I also have bad range with my microsizer. I think that you can get better range by extending the antennea on your car.
questions questions questions kasper01001 XMODS 12 01-02-2004 04:38 PM
MicroSizers Pro - 5 questions PauloBecker Bit Char-G / MicroSizers 10 10-03-2003 05:54 PM
Few questions CjsF150nNeon Bit Char-G / MicroSizers 13 02-03-2003 12:16 AM
motor and battery questions blght Bit Char-G / MicroSizers 5 01-02-2003 03:51 PM
Purchased 4 knock offs, 1 Microsizer on 5 freqs / results. AceQ Bit Char-G / MicroSizers 1 10-14-2002 11:49 PM
