Old 08-05-2003, 08:10 AM
inventerboy08 inventerboy08 is offline
Send a message via AIM to inventerboy08 Send a message via Yahoo to inventerboy08
help me
i just put in a duel cell in my zz and it wont charge when i press it forward on the charger the light turns red please help
im not short just verticaly chalenged
Old 08-05-2003, 08:24 AM
ClearStorm ClearStorm is offline
Team Mods Member
Send a message via AIM to ClearStorm
You need a custom charger to charge two batteries. Do you have one?
Eclipse ZZ w/ Microsizer PCB:
Also: 2.8 DKS Motor, Red Gears
Coming Soon: Civic body with Full BodyKit, Muffler, and Underglow.
Old 08-05-2003, 09:39 AM
no i dont please send me instructions to build 1
Old 08-05-2003, 09:43 AM
Team Mods Member
The site that i got my info from is no longer, so i wouldn't be able to instruct you.
I am sure someone else on this board could.
Old 08-05-2003, 11:02 AM
thanks 4 your help and it turnes out that some one has made 1 thanks again
tech
Old 08-05-2003, 11:12 AM
Team Mods Member
Yeah many of people have tutorials on this forum, just use the search function.
no problem
Old 08-05-2003, 11:44 AM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
well to make one just simple and affordable enough to work, you will need the following:
1 Radioshack 4AA battery case w/ ON/OFF switch
1 Spare ZZ Controller
1 Soldering Gun (optional)
Unscrew the ZipZap controller, and dismantle the two pieces. You will need to remove the charging base (the dock you put the car on) from the controller. Notice the base is connected to two red/black wires. Pull some of the black and red wire off of the inside where it is glued. Cut it off so that you have about 1" of red wire and 1" of black wire dangling off. So now you have a charging base with two wires hanging off it. You will need to cut off some of the insulation so you can see the bare wire. You can use a boxcutter, hobby knife, scissor, whatever you are comfortable with. Now just twist together the red bare ends from the base to the red bare ends from the battery case. Same goes for the black. Now this doesn't have a timer or something for you to configure the exact length of charging you need to do, so some experimenting will have to be done there.
Old 08-05-2003, 11:54 AM
thank u for the help ziprc it is really appreciated
Old 08-05-2003, 11:57 AM
charliebrown's Avatar
i did the exact same thing....only, instead of twisting the wires, I ripped the wires from the charging plate, removed the holder's and soldered the wires to the charging plate. I then used it to charge my car......the layman's dual cell worked great, but then I did the layman's tricell, charged it wrong, and got fried chips for dinner.....that joke is getting old.....fried chips....crunchy
Old 08-05-2003, 12:15 PM
Team Mods Member
For my custom charger, I drilled a hole in the back of my controller, and mounted a coaxil plug. I bought a wall power supply, and charge my dual battery zip with the wall charger.
Old 08-06-2003, 01:54 PM
i did what tinyrc said and it still dident work how long do u leave it on my batteries are tomy and are 50aaa instead of 10 does that make a diffrence
