Old 07-05-2003, 11:05 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
Arrow My track idea
Here is an idea for a track. I plan to use it with two booster cars running 2.8 - 3.4 motors. Do you think the lanes are wide enough, or to wide? Also don't go by the proportion of the picture. I ran out of room. Look at the measurements for size. I plan to use a peice of wood as a base. Should I do anything to the wood or just use it as a surface? Also what are good barriers?
Old 07-05-2003, 11:10 PM
moshbmxa's Avatar
moshbmxa moshbmxa is offline
TinyRC Car Killa
Send a message via AIM to moshbmxa Send a message via Yahoo to moshbmxa
looks like a fun track to me. i would probably get some poster board or thick paper to make the course. that may be too slick of a surface tho, i have never made a track myself and am wondering the same things (good barriers, surface).
Old 07-06-2003, 02:57 AM
rt450 rt450 is offline
guitars, cars and fishin'
i used a 4x8 sheet of plywood. sand it and paint it. for my barriers i used real thin walled 1" pvc pipe. it bends pretty good, and i just nailed it on.
don't lose your password
Old 07-06-2003, 03:03 AM
oops, i forgot. i also put charging pads on the outside wall. they're wired together to an ac plug. i just plug in the ac adapter into the track. to charge, just hold the car onto the pad for 30-45 secs. i'm using a universal 1000mah adapter @ 3v. works great!
Old 07-06-2003, 04:56 AM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
I think 8" is wide enough to race, your track plan looks good.
I used a 4x8 sheet of particle board, not the rough stuff this sheet was very smooth (and cheap$10).I put 1x4's around the outside edge(the cars will NOT leave the track area) primed everything then painted the surface with a flat charcoal colored paint (looks like asphalt) and I mixed some traction grit into the paint, rolled the paint on with a small smooth foam roller.The surface is smooth and has good traction.The 1x4 border boards are painted dark green with the top edge painted yellow as an aid to see the edge.My track rests on a 6 foot folding table.
I use three sets of zipzap race barrier sets and I can set really any track I can think of up on it (I do need a bridge section though) and still have track pieces left over.I also have three sets of the microsizer track sets and I only used one set so far but the pieces are good for a less solid barrier and little jumps if you like.
Old 07-06-2003, 08:54 AM
Master Debater
So I guesss I'll sand it down and paint it. Could I use rope as a barrier?
Old 07-06-2003, 10:32 AM
I have a beach ball...
I don't see any reason why rope wouldn't work. You just need something to keep the cars on the track right? Someone posted here awhile back some pics of an Initial D track made out of 1/4" foam board. To do the outline he just made two layers and cut out where he wanted the track to go.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 07-06-2003, 12:24 PM
moshbmxa's Avatar
TinyRC Car Killa
thanks for the info guys. anyone want to post some pics?
Track idea, comments wanted MoobY Tracks 3 12-07-2004 09:01 PM
track idea Squishy Bit Char-G / MicroSizers 0 01-29-2003 06:37 PM
Track layout idea Talon Bit Char-G Mods and Projects 0 12-31-2002 02:39 PM
My track idea... cowfish_29 Bit Char-G / MicroSizers 18 09-30-2002 09:39 AM
What do you think about this track idea? sneuburg Bit Char-G / MicroSizers 1 09-08-2002 05:30 AM
