05-17-2003, 03:31 PM
Redneck Drifter
prob. with zip again
i am having a problem with my zip again..i got a "high speed gear set" for microsizers, but now my car goes badly to the left. i had another microsizer gear set on before that and it when straight. i ajusted the little white thing the other way and it still turn hard to the left when going straight. The axel has alittle play side to side while on the car...does that have anything to do with it? thanks
05-17-2003, 03:59 PM
did you check under the magnet...there may be some kind of metal dust that builds up
05-18-2003, 12:59 PM
Are you using the same tires? If one tire on the rear axel had more grip it would pull right or left. Maybe try new or different tires, and switch sides to see what happens.
My humble ZZ collection:
-Lowered champagne Civic
-Silver 350Z
-Blue RX-8
-Motor/Gear upgrade kit w/ 2.8 motor
-2F2F kit w/ 3.4, Evo, & Eclipse
-2F2F Skyline and S2000 bodies
-Awesome RC 2F2F Lancer Evo
05-18-2003, 01:43 PM
That's all folks
Sometimes the wheels will slip on the axle. Grab hold of one wheel and see if you can spin the other wheel, if so this could also be the problem.
That's all folks!
05-22-2003, 06:15 PM
MASTA POOOOOOOOOOOOOOTANG
what happened to me was i pulled my gears off my microsizer 2 fast and 2 furiouse (haha) but ne way in the process i bent the axle without me knowing and when i put it on mi other microsizer it wouldnt go straight. thats probably what happened to you. try taking the axle off with the tires still on it then roll it on a desk and see if its all funky looking. one of the wheels should wobble. if thats the case your done with it. if u bend it back u will most likely bend it at the wrong spot making it worse so dont waste your time.
MICROSIZER PRO:  2 SPEEDS, 1.3 NIMH, 49 MHZ, SKYLINE R34 GTR custom paint, pull back wheels, blue head lights
MICROSIZER SPORT:  1.3 nimh, rest is stock
panther=  2.4 nicd, rest is stock
MEGATOYS rc:  rest is stock
bitchar-g:  rest is stock
