Old 12-22-2002, 02:44 PM
Fury Fury is offline
3.0 motor problems
Hi there
I've had a bit of a search on the forum, and i can't see if anyone has found a solution.
I just got a 3.0 motor from QFM - my problem is that sometimes my bit will get stuck if i stop. Quickly going in the opposite direction will then seem to "free" it, and it'll go again.
I've taken a good look, and it looked like the motor gear is not quite meshing - i've solved this by adding a very thin bit of plastic to move the motor closer to gears. This stops the gears sticking (they run nice n smooth now ), but it still stops occasionally.
(BTW - i am using the right gears )
Is there anything else i can try? I've tried changing position with screws at the back, lubing anything which moves, etc - is there anything else like "running the motor in" (whatever that means)
Thanks
Old 12-22-2002, 04:21 PM
swe_modder
I hade the same problem, but it does't get stuck.
The problem can be that your plastic is to thick and gets your motor too close to the gears try to thiner it abit.
I hope it gets better!!
Old 12-23-2002, 12:38 AM
Dratheus's Avatar
Dratheus Dratheus is offline
Bâshbad the Wicked
I'm wondering if your idler gear is rubbing against your tire?? If so, you could reverse the pinion gear on your motor, creating a ridge to keep the idler in place.
Stay out of the DAYLIGHT!!!
Old 12-23-2002, 01:02 AM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
Send a message via AIM to Pojo
3.0s were destined for a problematic future...as they are actually meant for Bit Racers! Solution = Any OEM 3.1+ engine. I recommend the wonderful 3.5 by Bitmod1!
Old 12-23-2002, 02:38 AM
spikeymike218 spikeymike218 is offline
TinyRC Sith Lord
i also get the same problem, but not as often. i'm running the 2.6 motor, my gf who also has a 2.6 experiences the same problem. gets kinda annoying sometimes, but we just learn to live with it.
Mine: red S2000 27mhz
Hers: blue subaru WRX 45mhz
Mods:
2.6 motor
8.25:1 gear axle
medium tires/soft stabilizer bars
l.e.d headlights
rare earth magnet
Lxx 3.0 motor vs Bit Char-G motors bill Bit Char-G Parts and Hop-Ups 36 12-26-2002 07:53 AM
Lxx 3.0 motor vs Bit Char-G motors bill Bit Char-G / MicroSizers 3 12-06-2002 09:47 AM
Prb with 3.0 engine Seb123 Bit Char-G Parts and Hop-Ups 1 09-12-2002 01:31 PM
Preserving a 3.0 engine. . . andrzejpw Bit Char-G / MicroSizers 4 08-15-2002 05:32 PM
