Old 03-10-2005, 03:22 PM
jon.jon's Avatar
jon.jon jon.jon is offline
Thumbs up New aluminum rim small review.TOPCAD
New aluminum rim review these things are tight same size as mini-z rims the offset is just right I give them a 10 out of 10.
Are they worth $30? I dont think so, but would I buy another pair yep. now I just need some mini-z tires because xmod tires will slide right off.
Old 03-10-2005, 03:23 PM
jon.jon's Avatar
Old 03-10-2005, 03:31 PM
jon.jon's Avatar
last one
Old 03-11-2005, 05:00 AM
Silentbob343 Silentbob343 is offline
Now if Topcad would start making other alloy parts to compete with GPM.
Old 03-11-2005, 01:08 PM
dragon4450's Avatar
customanix
i dont know man $30 sounds like alot to spend for parts for something that costs $50
Old 03-11-2005, 06:43 PM
Let's see, he has a brushless motor and ESC as well as a CF chassis. I would say that xmod is worth much more than $50.
?Jon.jon any reason you didn't go with a Mamba package It looks like you are using a Feigao motor. What ESC are you using?
Old 03-12-2005, 12:54 AM
jon.jon's Avatar
Topcad and GPM competing, that would be nice because Im sure prices would drop.
You guessed it it is a figao. I didnt want to use the whole Mamba setup because the Mambe motors pull way too much current for just this little setup. Some have used li-polys to fix the problem but I went with 3 li-ions and a brushless motor that pulls less current but still performs like the big dogs. But I am using the Mamba ESC with the Figao motor.
Old 03-12-2005, 12:12 PM
GuiltyEnder GuiltyEnder is offline
Send a message via AIM to GuiltyEnder
Those are nice, jon.jon your Xmod has hardly any radioshack left
Old 03-12-2005, 03:33 PM
JustinL42
jon.jon,
Am I seeing correctly that the rear rims are wider than the front rims? It didn't seem to mention this when I ordered mine but from your pics it looks that way. I hope they are. How long did it take you to get them from dinball/rcmart after you ordered?
Thanks,
JustinL42
Old 03-12-2005, 04:11 PM
jon.jon's Avatar
Originally posted by JustinL42
jon.jon,
Thanks,
JustinL42
Yep the rear is wider than the stock wheel and the front is narrower than stock its hard to tell from the picture up there.
Normal shipping takes at least a week or two. I was thinking of getting another set but I need tires for my first set .
Old 03-12-2005, 11:02 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
it's probably the same 8.5mm front and 11mm rear wheel dimernsions as the mini-z wheel. this is a good thing as it will open up the huge line of mini-z tires that are available
Old 03-13-2005, 04:47 AM
JustinL42
Getting access to a larger selection of tire compounds was my main reason for buying them. Sweet..
JustinL42
Old 03-14-2005, 05:05 AM
HammerZ's Avatar
HammerZ HammerZ is offline
Thrasher
The only downside I see is that these are the same size as the Mini Z wheels. Of course it lowers the car for better handling, but the Xmods have very little clearance to begain with. With that said when you hit a corner in a lowered car and the chassis hits the ground it spins out. I am looking for an inch up type soon.
Last question, would the TinyRC shop be looking into stocking these?
Old 03-23-2005, 04:02 PM
viperdout's Avatar
It's Really Fast!
I'm running Mini-Z wheels on the back of mine, and I notice no drop in back (I use foams, but with rubber tires there's no change either:
Mine also uses the Tiny RC chassis.
Project Bad Brushless:
Just say no to giant sigs.
Old 03-23-2005, 04:14 PM
jon.jon's Avatar
where did you get the foams from?
aluminum instead of brass??? BiLLy bOb TTTT 35 03-29-2007 12:55 AM
Aluminum Lock Nuts Group Buy (Xmods & Mini-Z) Namuna XMODS Parts and Hop-Ups 1 07-26-2006 08:09 AM
SE: POST YOUR CUSTOM WISHES! (small shops take notice) potentiality ZipZaps Mods and Projects 9 01-21-2004 08:51 PM
Small wheels... We don't need no stinking small wheels! Blamminator Bit Char-G / MicroSizers 0 02-04-2003 09:12 AM
Southern California Small Scale Race Breeze Events 0 01-27-2003 12:47 PM
