Old 01-27-2004, 08:16 AM
aperson's Avatar
aperson aperson is offline
Dual Electronics
I dont know if this will work but i was thinking about putting 2 sets of recievers in one of my cars. i dont know exactly how to go about doing this though.
will both revievers be able to work on the same frequency?
will i need diodes anywhere between the motor and the electronics?
Old 01-27-2004, 08:19 AM
RC 2NR RC 2NR is offline
TinyRC XModder
Why would you want to do that?
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 01-27-2004, 08:44 AM
aperson's Avatar
2 sets of electronics=2 sets of 6 cell mods =14.4 volts = lotta power
Old 01-27-2004, 09:56 AM
TinyRC XModder
Oh, not a bad idea, but, it just doesn't seem like it would work.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 01-27-2004, 11:32 AM
aperson's Avatar
if the 2 can run on the same frequency all i have to do is rig them up so that they are clones of each other and jump the pos on one to the neg on the other side and hook the other 2 up onto the motor.
Old 01-27-2004, 11:53 AM
Rez Rez is offline
If the only reason to do this is to deliver more voltage to your motor, there are better ways to go about it. FETs, relays, regs, etc. Besides, you're going to need all the space you can get to pack the batteries for those volts, right?
Rez
a7i20ci7y
Seven Cities RC
Old 01-27-2004, 02:33 PM
3series takumi's Avatar
mini-eX-Driver
that wont work bud. you cant run 2 recievers from one Tx. how the receiver reads the info and reacts is not perfect. so you will have 2 receivers doing slightly different things fighting with eachother.
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 01-27-2004, 02:50 PM
Cian's Avatar
Cian Cian is offline
Got Cheese?
So, is there any way of using the receiver on one board to control the speed control on two ?
Lisa: And vice versa...
Old 01-27-2004, 03:24 PM
shane-o shane-o is offline
Send a message via AIM to shane-o Send a message via Yahoo to shane-o
plus...
think about it... you add all that crap... 2 sets of electronics.. and 6 batteries... defeats the purpose of the xmod
Quick!!! look ahead! see that!?!?! ITS MY DUST!!! BWWWAHHHH AAAAAH HAAAAAA
Old 01-28-2004, 08:12 AM
aperson's Avatar
what do you mean defeat the purpose?
Old 01-28-2004, 09:12 AM
scatmanjohn01 scatmanjohn01 is offline
it will way a ton and barely move.
Old 01-28-2004, 10:24 AM
EXACTLY
think about it... you add all that crap... your case wont even fit...
and to tell you the truth... if... *which if isn't even a possibility*
you pulled it off... you'd have a tiny car... with a bunch of JUNK all over it. i mean... guys already are havin difficulty finding room for 6th cells... none the less 2 boards for electronics and 12 BATTERIES... lmao...
again... interesting idea... but not probable.
Old 01-28-2004, 12:15 PM
neurokinetik's Avatar
Sure, but if you are doing that, you might as well do the external FET mod instead. It would handle more power than two stock boards, and it can also handle the voltage. All that would need to be done is to upgrade the Zener diode on the main board, or use a regulator in its place.
*Idea* I could probably build a version of my board that had the regulator built-in. What you would do is wire the power directly to my board, and then use the 5V output from the regulator to feed the stock electronics. With that kind of setup, you could do almost anything, with no risk at all to the stock electronics.
Old 01-28-2004, 12:34 PM
Mr BigShot Mr BigShot is offline
TinyRC PRO Modder
Theres also RELAYS
Go to Mr BigShot's Must See UpGrades in the Xmod science area to read about relays . With Relays you can run all the volts you want .
Old 01-28-2004, 12:45 PM
Rez Rez is offline
Actually, this sounds like a hell of an idea. Itcould be a really easy drop in, especially if it had clear places to connect the existing wiring.
Rez
a7i20ci7y
Seven Cities RC
From Dual To Tri-cell???? G-Force Bit Char-G Mods and Projects 1 11-08-2003 12:42 AM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 06:12 PM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
