Old 04-28-2003, 01:07 AM
Epochracer34's Avatar
Epochracer34 Epochracer34 is offline
Esc set up for mini X?
Ok, i followed the directions, tried several times, several ways, even reversed the forward reverse switch, but no matter what I do its not right. Im using a new Kyosho Perfex controller like several other people have had success with, but the best I can get it to do is reverse ok, but when I run through the forward speeds its fine til I have the trigger pulled all the way back, when i reach this spot the car wont move, but if I let off just a little it catches and will run. its like the controller trigger travels too far back. then wont go, So i rigged a trigger stop so it wont got all the way back. then its fine, anyone else had this problem and figured out what to do?????
Epochs Rule!!
Old 04-28-2003, 02:26 AM
bluemax_1 bluemax_1 is offline
Not entirely sure why this is but there seems to be a minor incompatibility between the Kyosho Perfex and Mini-Xs. This odd glitching is one of the symptoms. Sure hope you didn't buy it as a kit this way. Some people don't experience the glitching but a lot do trying to use the Perfex Tx with a Mini-X. That's why a Futaba is recommended. (As cheap as a Perfex but no glitching)
Old 04-28-2003, 12:04 PM
i may have to get a futaba, i didnt pay extra for the controller, im using the same controller I was using for my mini z and overland. thanks for info.
Epochs Rule!!
Old 05-22-2003, 08:34 PM
deviant deviant is offline
Send a message via AIM to deviant Send a message via Yahoo to deviant
i have been using a TRAXXAS TQ transmiter and i have noticed the same prob with pulling the trigger all the way back... i just assumed that it had somthing to do with the ESC's setup system... i set it up 5 or 6 times and it always ended up with the same travel problem...
Old 05-24-2003, 12:40 AM
irc irc is offline
I found that twisting the servo wire reduced the glitching. I also added a servo wire extension and had good luck removing the glitching that way also.
" THINK FAST "
Add light set to your non ZZSE bodies! 'Vette Nerd ZipZaps 1 08-29-2006 04:18 PM
BCG Drift Set: Useful? ownzorzor Tips, Mods and Reviews 0 10-17-2003 03:49 AM
FS: Brand New Micro RS4 RTR set, DigiQ DRS-04 RX-7, DigiQ DRS-03 Pitworks Skyline bluemax_1 For Sale/Trade 7 06-17-2003 11:40 PM
Initial D, or AM set? nrmcj Bit Char-G / MicroSizers 9 04-16-2003 10:43 PM
