Old 01-29-2003, 12:52 AM
dustn's Avatar
dustn dustn is offline
Poor Student
Quick I need to know wheelbase of ZZ... Please?
Building custom wb bit clone and need to know how long to make wheel base of zipzap or preferably slot car. Thanks.
Fight Crime <--> Shoot Back
Old 01-29-2003, 01:10 AM
Fourustwentius's Avatar
Fourustwentius Fourustwentius is offline
Help Me!
You my freind, need a ruler! For $29.95 I will send you your very own!
At the bottom.
Old 01-29-2003, 01:15 AM
dustn's Avatar
Poor Student
But I dont have a zz... the problem is that i am making a chassis (full-length) and all i have are KIT racers and Bit clones... So I have nothing to go from. I want it to fit lexan slot car bodies. Right now I'm just using the KIT body, extended.
Old 01-29-2003, 01:17 AM
Help Me!
I've gotta bit char broiled. will that work
At the bottom.
Old 01-29-2003, 01:19 AM
dustn's Avatar
Poor Student
mmm sounds yummy but unless its extended, no dice.
Old 01-29-2003, 01:20 AM
Help Me!
44mm by 27mm
At the bottom.
Old 01-29-2003, 01:23 AM
dustn's Avatar
Poor Student
That seems sorta long but then again you drive a hippie bus. My hotwheels MR2 measures 41mm. Thanks for your rapid response btw.
Old 01-29-2003, 11:03 AM
dustn's Avatar
Poor Student
so can anybody measure their zz for me?
Old 01-29-2003, 12:40 PM
Subie Driver Subie Driver is offline
'00 Subaru Impreza 2.5 RS
4cm long x 2-3/5cm wide
Length is from axle to axle, width is from tire center to tire center, and should be the same as a Bit, since the rear axles are interchangable. Hope this helps.
27MHz Microsizer White Peugeot 206: 3.8, NiMH
49MHz Microsizer Yellow Lancer Exolution: stock
27MHz LXX Char-G Xanavi Skyline GT-R: 3.0
27MHz ZipZap Yellow F&F Civic: 2.6, Carbon Fiber-look hood, lowered, sport tires, turbo gears
Old 01-29-2003, 03:55 PM
dustn's Avatar
Poor Student
Thanks. That does help immensely. Now off to make a custom steering setup...
Old 01-29-2003, 07:06 PM
No problem, it was simple request that was simple to answer.
Overland and MR-01 wheelbase bugman72 Mini-Z - Mini-ZRacer.com 2 07-10-2004 06:24 PM
longest wheelbase setting cdog4w ABC DTM SP 2 05-27-2004 05:51 PM
wheelbase question wooha XMODS 3 01-01-2004 10:17 PM
Tamiya Wheelbase Sizes HaCo Mini-X 6 01-13-2003 10:52 AM
quick newbie question bojangs Bit Char-G / MicroSizers 2 10-06-2002 12:44 AM
