Old 01-09-2003, 11:21 PM
Suntzu28 Suntzu28 is offline
Dual cell mod ( will 2 - 50 mah's achieve + speed?)
ZZ's come stock w/ 100 mah NIMH batts.
I want to perform a dual cell mod with 2 - 50 mah's ( i have extras laying around). Will the dual cell mod achieve the same speed results as it would w/ a dual cell mod using 100mah's? I would assume the only difference would be the run time... but i have never done a 2 cell mod.
Dual/Triple Cells Available
66 Pontiac GTO, Chevy S10, 69 Doge Charger, Hummer, Escalade, Acura Rsx Type S
Old 01-10-2003, 10:28 AM
Namuna's Avatar
Namuna Namuna is offline
Voltage = Speed
mAH = Runtime
As long as you setup the 2 batteries in Series (Series = voltage adds together, so it would come out to 2.4v) then the dual pack will equate to higher speed.
Old 01-10-2003, 06:11 PM
Namuna....last night i performed the dual battery mod in my ZZ using a parallel setup unwittingly. I now know this only increases run time at the sacrifice of speed ( extra battery weight). My question is ..when i set up the series diagram i would think the batteries would get hot / blow up. The reason i say this is because i hade a wire leading from the (+) contact on the chassis to the (-) contact on the 2nd battery. Then from the 2nd batteries (+) end a wire leading to the chassis (-) contact and the thing got MAD HOT.
The series set up seems to be exactly the same so what gives?
Is my series set up wrong?
(+) chassis contact w/ wire leading to (+) end of 1st battery
(-) end of 1st battery connected by wire to (+) end of 2nd battery
(-) end of 2nd battery connected to (-) chassis contact
Old 01-10-2003, 07:18 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Your batteries are probably shorted out. Check your insulation. Oh, and don't forget to mod your PCB for best results, this increases current to the motor while dual-cell increases voltage. both these are good.
Old 01-10-2003, 07:34 PM
sipsap's Avatar
sipsap sipsap is offline
Race them naked
hi it seems you are having trouble "i read your post on the other boards" here is the dks diagram i used to do the dual batt mod it works great but the pic is for a bit so pay close attention to what you are doing and this should work for you it did for mehttp://www.driftkingshop.com/dualbatterymod.html
Old 01-11-2003, 12:51 AM
Thanks a lot Sipsap . I finished the mod and it works well. The only problem is i cant get the Body on the chassis. Have ou performed a dual battery mod ( and if so how did you get the body back on the chassis)?
Old 01-11-2003, 08:16 AM
sipsap's Avatar
Race them naked
very carefully i used the civic body and it was a very tight fit i also tried the porsch but it wasent going to happen but now i have done the pcb swap and the much smaller pcb lets you slap any body you want to on there
Old 01-11-2003, 09:57 AM
Nathan's Avatar
Bad Driver
I just put some tape on my PCB cover and pushed it down. No muss, No fuss.
and they said it couldn't be done! dual cell mod tory_103 Bit Char-G Mods and Projects 5 01-01-2003 07:03 PM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 10:23 PM
did the dual cell mod - a few questions from a newbie here PhillyB Bit Char-G Mods and Projects 7 10-29-2002 12:03 PM
