For the Zips, the best you can do is to look for HO scale water slide decals. These can be found on Ebay or at your local HS. You can also use the rub on or pressure sesitive decals made for pine car racers too.
Larger scales can be found on Ebay as well. Have you tried simply typing "decals" and a scale into google?
Of course, water slides with a good coat of clear gloss will give you the best results.
