Old 05-10-2006, 05:41 PM
flamehead_16's Avatar
flamehead_16 flamehead_16 is offline
Naruto Champion
6th cell
can i attach a 6th cell on the truck straight were the batteries meet the board.
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
Old 06-13-2006, 10:39 AM
p4tch
Where does it go.
I also need to know where it goes on bothe gen1 and evo cars?
Please help.
Old 06-13-2006, 08:30 PM
Jazz32
When you want to increase your voltage, you have to break the existing loop and series connect new batteries.
For the Evo's, I unsolder the red wire on the pcb and solder that to the negative of a battery holder. Then, I solder the positive of the battery holder to where the previous red wire was attached to the pcb.
On the gen 1, I cut the wire that goes between the two battery holders and add one in there. Again, the batteries need to be wired positive to negative all the way through.
Old 07-01-2006, 12:40 PM
bengali548's Avatar
bengali548 bengali548 is offline
(insert something funny)
for gen 1 is it ABSOLUTELY nessecary (yea ha ha i made a spelling mistake) to solder the wires i did it to my evo by cutting wires so for a gen 1 why cant i just cut the wire use tape and wrap it up (thats a pun remember safe sex kids)
Old 07-01-2006, 01:47 PM
Jazz32
In that situation you can. I still recomend solder because then you know the joint isn't coming apart and you have a better connection. When i'm testing things I twist wires together all the time. But when I'm finally done, I go back through and solder them.
Old 07-07-2006, 02:37 PM
bengali548's Avatar
okay im going to get a honda civic body does any one know if 6 cells will sit cosy in it
Old 07-07-2006, 04:41 PM
Jazz32
2 cells sit nicely on top of chasis under the body. That's what i formerly used on my blue civic.
Old 07-10-2006, 11:03 PM
bengali548's Avatar
okay could someone explain to me the whole thing about the extra battery holders touching the antenna and short circuiting and if someone could give me a tip to prevent that it would be appreciated
also if i add 6 cells its fine right or will my xmod blow
6th cell power to weight worth it? RGM1524 XMODS Mods and Projects 24 03-31-2004 08:02 PM
if you have a 6th cell ViperKid XMODS Mods and Projects 6 01-19-2004 11:02 AM
I need help with a 5th or 6th cell installation... Chaos Fire XMODS Mods and Projects 3 12-24-2003 11:00 AM
