Old 10-17-2002, 11:02 PM
NorCalCoug's Avatar
l33t camber wizard :)
Question Issues with battery modding..
Okay, when I try to hook up a battery mod (not the dual 2.4v but a 6v setup), the motor will only spin in reverse; when I hit forward nothing happens. When I put the stock battery back in it works both ways. I also tried it with a 3v setup, same thing. Tried this on 4 different chassis, 1 bit and 3 generics. Any ideas?
Old 10-18-2002, 07:30 PM
NorCalCoug's Avatar
Anybody? :P
Old 10-21-2002, 09:12 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Have you tried removing the axle and step-down gear to see if the motor spins without the added weight?
Old 10-21-2002, 09:47 PM
NorCalCoug's Avatar
Yeah, that was with just the motor in (no gear no axle, just pinion so I can watch it spin. I solved the problem though. I tried 3 different batteries, and the 3rd one worked. The first two were giving out weird oscillating pulses that the third didn't. I dunno. Weirdness.
Old 10-21-2002, 09:50 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
ill give it a shoot
well im guessing that some how one of the wires is hitting the heatsink and making the motor spin if a wire is on the heatsink then the motor will do that hapened with mine be sure to have all the wires covered almost hope this helps well i guess nvm if you fixed it
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Increase short battery life! underglow ZipZaps SE 1 09-17-2005 06:51 PM
